Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Ace mower MTD ?
I have an Ace riding mower, MTD #1-330220-4MTD 13AN673G033 SER # 1K300B30128 I can't find the right manual on the MTD website, any suggestions ? My problem is the blade drive belt comes off while in the up position.  There is too much of an angle between the engine pully and the deck pulleys, how to remedy.  Thanks
  • jonesebaby Mar 24, 2009
    It was helpful and I appreciate any and all help on this problem.  The studs are close to the pulleys and belts.  I think the problem is the mower deck is worn out tnd racked to one side.  I decided to get a John Deere Thanks Guys
5 Suggested Answers
steveym
  • 11 Answers
SOURCE: i have a mtd 13.5 horse 38 inch cut 6 speed its
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
Posted on May 03, 2009
  • 246 Answers
SOURCE: MTD 50" belt problem
Hello:
There May be a Pulley that the Belt is Not Routed onto.
Use the Breakdown at the Following Site Addy to Locate the Deck and Belt Routing Breakdown.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
darjr
  • 378 Answers
SOURCE: My engine runs fine, but
check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
  • 53 Answers
SOURCE: how do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Posted on Jul 08, 2009
How can I find a manual for my MTD mow master 11hp ride on mower, model number 1333A
Try mtd website. Usually the real model number is longer than that...check the tag on the mower for another number.
Jul 17, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
I need a parts manual for mtd model 95178.riding lawn mower
Go to MTD website and down load a manual.
May 13, 2014 | Mtd Garden
Mtd riding lawn mower, drive belt
Go to MTD website and download the manual for your machine.
Apr 21, 2014 | Mtd Garden
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
Need a manual for a Model 13AF608G062, Serial #1E292H10446 MTD Yardly Riding Mower
If you go to the MTD website you can enter your model and serial number and you will be able to download your manual.
here's the link - http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Jul 18, 2011 | Yard Machines Garden
Repair manual MTD riding mower Mod 136Q699H205
I tried to find a manual on MTD website but without the serial number it would not find it. I can tell, if you did not already know this, it was made in 1996 and sold by Mid States. When you get to the website with the information, you should be able to find an IPL to look at parts you need.
HTH
Good Day.
Oct 29, 2009 | Mtd Garden
MTD hydostic riding mower brake won't release
Check the MTD website, they may have manuals to download or online help.
Sep 07, 2009 | Mtd Garden
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
318 people viewed this question
Top Mtd Garden Experts
Dwain Pippen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Mtd Garden Expert? Answer questions, earn points and help others
