Question about Garmin StreetPilot C330 GPS Receiver
Street pilot c330
Will not power up just turned off and now nothing, fuse is good vehicle plugs are good.
  • 31 Answers
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot c330
Pull the face off try to reset it, if it will not reset, or work in the car or the house, the battery needs swapping out,
Garmin $100
Regards
Jun 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
My street pilot c330 wont power up
I am continually amazed by how many people list there problems with only the barest of explanation. How on earth do you expect a reasonably informative answer when your total description of the problem is "my street pilot c330 wont power up"? OK, so tell us more! Did it work just fine until one day it stopped? Did you let it sit for 6 months and when you plugged it in again... nothing? Did you check the fuse in the power cord? Oh, you didn't know there was a fuse there? Read the book! If you want help from me, kindly describe in a bit more detail just exactly what the problem is, a bit of history of what, if anything, led up to the problem, etc.!!!
Jan 27, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin won't stay on
Oh man.. I also bought the c330 on black friday... powers on and wont get past the blue street pilot screen--just shuts off! Will "work" when connected to the PC, but who's going to drive around with a computer?
Is Garmin doing anything about this?
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
87 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
