Question about Whirlpool Washing Machines
The error F23
I have a problem with my whirlpool washing machine. it stopped in the middle of the washing process and showed the error F23. the model of the washing machine is whirlpool AWO/D 43135.
  • Anonymous Mar 18, 2014
    Help
  • Anonymous Mar 21, 2014
    Washing machine won't come on
    Genius:
  • 1,550 Answers
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
My whirlpool high energy washing machine style master #907675 just stopped working in the middle of the wash cycle. What can I do to get it to start working again?
not a good model # check on face of opening inside door frame.
door lock switch maybe your problem depending on model#
washer should show error code on electronic display by lights flashing or led read out if not lighting up can be control board check your home power first
Jul 03, 2016 | Whirlpool Washing Machines
My brand new Whirlpool AWO/D 7740 shows error code f23 5 seconds after starting any program and won't do anything.
don't touch it
as it is still under warranty , call in a service technician for a warranty repair
Jan 28, 2016 | Whirlpool Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I am having a problem with my Whirlpool AWO/D 43135 washing machine.It stops when starting any program and shows error code F23.What should I do?
The fault F23 could be linked to the water temperature not reaching the right temperature. If your model uses hot water inlet connection then check if your hot water unit is providing the correct inlet water temperature. Otherwise it is likely the temperature sensor or heater element maybe failing.
See description
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86degF (30degC).
1. Unplug washer or disconnect power.
2. Check connection to water heater.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
Jul 31, 2014 | Whirlpool Washing Machines
F23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Jul 04, 2012 | Whirlpool Washing Machines
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Sep 09, 2009 | Washing Machines
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
Washing Machines Logo
3,589 people viewed this question
Dan Webster
Dan Webster
Sal De
