Question about Sony DAV-X1 System
Sony dav x1 blocked = show VACS 0 message
My DVD home theater system SONY DAV X1 is blocked = any of the functions seems to be working and it shows a message VACS 0. Thanks
5 Suggested Answers
SOURCE: Audi but no picture when cable box conected through DAV-X1
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Posted on Jan 15, 2008
rizla
  • 1463 Answers
SOURCE: How can I make DAV-x1to read multi-regional DVD
have a look here SONY DAV-X1 (DAV-X1) Multiregion remote hack upgrade @ multi-region upgrades www.multiregionupgrades.com
riz.
Posted on Mar 27, 2008
bugpowder
  • 28 Answers
SOURCE: sony dav-x1
The simplest solution would be connect the headphone jack on the iPod to the stereo audio inputs (RCA) to your home theater. So you need a cable that is "stereo phono mini jack" on one end (into iPod headphone jack), and then Y-splits into two RCA connectors on the other end (into L and R audio in on the receiver).
The expensive Apple-endorsed Monster-branded version can be found at http://store.apple.com/us/product/TN983LL/A#overview for $30, but you can get the same thing at Radio Shack for $7.
http://www.radioshack.com/product/index.jsp?productId=2102974&cp=&sr=1&origkw=phono+jack+rca&kw=phono+jack+rca&parentPage=search
Set the iPod volume to less than ~80% and then control the volume using your receiver. You have to use the iPod menu to select music.
Posted on May 12, 2008
tech48
  • 624 Answers
SOURCE: HCD-X1
There is only one thing that you can do as the end-user to try and fix this. Try cleaning the lens on the laser pick-up. Most retail outlets that sell CD or DVD players sell a cleaning disc for about $10 to $15. You put it in the machine and let it run for about 20 to 30 seconds. If the reason your DVD player won't play is because the lens is in need of a cleaning, this will fix it. If the reason is anything else it will not help at all. The most common reason for this failure is a faulty laser pick-up that need to be replaced. This is the most common and usually the most expensive repair because of the cost of the pick-up. It can cost anywhere from $130 all the way up to $200 depending on the labor rates of the shop and how much they mark-up the cost of the pick-up. All shops mark-up the cost of the parts. It is not advisable to do this yourself unless you have some experience with electronics and can do some troubleshooting to verify that the pick-up is indeed bad. It is easy to cause more problems than you started with if not done properly. As I stated above, it is the most common, but it is not the only reason. Other causes of this failure can be as simple as a bad voltage regulator or as difficult as replacing a servo IC. It can also be a memory IC (if it plays CD's but not DVD's), a spindle motor, a bad gear or switch, or one of many other causes. That is why it requires some experience troubleshooting them to nail down the exact cause.
I hope that this information was helpful for you to make a desicion on what to do with it, and if so, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free help and information.
Let me know if you have any more questions, I will be happy to offer you whatever help I can. I have over 18 years experience repairing these type of products. I have been repairing DVD players since they came out on the market for sale.
Dave
Posted on Sep 16, 2008
mrwtech727
  • 75 Answers
SOURCE: Need manufacturer set up code
It should be one of these: 31759, 30158, or 31758.
good luck!
Posted on Sep 16, 2011
Dav-x1 no audio
Most likely some one hit the wrong button on the remote. Make sure you have the proper device selected and the tv is setup for the proper device input. It is hard to tell you what is exactly wrong due that I do not know the full extend of your system.
Mar 27, 2012 | Sony DAV-X1 System
Type your question here...
I am having SONY DAV-DZ100 DVD Home theater system. The player is reading all the MP3 format cds and If I Insert any DVD, the message showing as "can't play this disc", even its a new DVD. Please suggest the solution.
Oct 12, 2011 | Sony DAV-DZ100 System
Sony dav -1x speakers cables
ur best bet is to go to a target storee, best buy, or abc warehouse, thats where i got mine they were well under 100 dollars
Jul 27, 2008 | Sony DAV-X1 System
Sony DVD Home theatre system
lets perform special reset function in your home theater.
1= set to stand-by mode
2= press three buttons of "Stand-by, Function & Volume- " all togather.
3= you will see "Cold Reset" message on front display of set.
4= power up and enjoy ;)
May 28, 2008 | Sony DAV-X1 System
Dec 25, 2007 | Sony DAV-X1 System
Need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
Nov 03, 2007 | Sony DAV-X1 System
Sony DAV-X1 System Logo
240 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
