Question about Nokia 6030 Cellular Phone
Modem hardware failure
Every time i connect my phone to system and try to connect internet it says that modem hardware failuer or modem unplugged
    Scholar:
  • 145 Answers
First of all, download and install the latest version of Nokia PC Suite.
Now try again. If the problem exists, Try chaning the USB port .If same,Try with a new data cable( or borrow one from your friend). IF still problems,Try Hard reset your phone. If still problem, Try changing phone's software.
I think your problem should resolve with this.
Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Posted on Feb 21, 2009
How to connect my xperia x8 as a modem to connect to my laptop to use internet?
you can connect it by data cable or wirelessly by bluetooth once it is connected to your computer open the program for your phone (it comes in dvd/cd with phone)
then select connect option to connect internet from your phone as GPRS or modem as you need
remember when you first time connect phone with computer it shows notification new hardware found and installs your device as standard modem also you can select your phone as modem in control panel also
further the same procedure to make new connection
good luck
Aug 20, 2011 | Sony Ericsson XPERIA X8 Cell Phone
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
Not able to access internet using samsung corby s-3653 as modem connection to pc
have you tried configuring your internet access through your samsung pc studio? if not, open your pc studio, connect your phone and create an internet access through internet connector and try to connect.
one way to check if you can connect to inet by using your phone as a modem, is, surfing the web first using your samsung corby's web browser.
if you can't connect or surf the web by phone browser, it means you still haven't configure your browser profiles to your network provider. ask the right configuration from your network and configure the browser profile first.
good luck..
Feb 26, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
There is an Error 692 : There is hardware failure in your modem.
Dear!!!
Error : Hardware failure in port or attached device.
Solution :
1. Check to make sure the correct modem is selected in the dialer.
2. Make sure there are not multiple modems installed.
3. Uninstall and reinstall the modem.
4. Make sure that no other programs are using your modem. Fax software, Supervoice, etc...
5. Ctrl-Alt-Delete, if you see RNAAPP loaded,
6. Send to manufacturer?
Dec 14, 2008 | Multitech Systems MultiModem II MT2834BL...
Dialup 56k modem not responding.help says harware failure
whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Nov 15, 2008 | Compaq 56K Modem
Every time we try to use the internet it says unable to find server, if we unplug the ntl modem and plug it straight back in the internet connects how do we solve this
sounds like the internet connection is not setup to Ur modem. When u unplug it redetects the modem and connects. try uninstalling the modem from the control panel - system - device manager. keep the modem connected and reboot. U may have to use control panel - add/remove programs any programs the modem cd installed. on reboot use the modem cd only to get the driver and let windows control the modem.
May 26, 2008 | Computers & Internet
No green light on modem for internet, all others solid green/Seimans 4100B from at&t
Check if the hardware (modem) is recognised in the device manager (icon my computer > right click, > properties, > hardware, > device manager).
  1. if its recognised then right click it select properties and then select diagnise and see if your computer is communicating correctly with your modem.
  2. If its there but fails to diagnise then goback to the device manager update the driver and try process one again.
  3. if its there and diagnise well, then all you need is restart your computer after turning off other potential modem devices eg mobile phone connections or bluetooth, after restart try using your moddem once again (I am assuming you havent deleted any important files or change your settings.
  4. If three fails, then restore your computer to an earlier time when you were still able to use your modem (start > all programs > accessories > system tools > system restore ) and follow the procedure that follows.
Mar 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Hardware failure in a modem error-692 in samsung explore
try go to your control panel open phone and modem delete the samsung modem in there and re install it.
Feb 10, 2008 | Cell Phones
Nokia 6030 Cellular Phone Logo
54 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
