Philips 170c Lcd star`s but it didn`t remains on
The monitor starts .It shows the image (Check cable connection ) then itgoes down , but the power led remains green . The monitor it is notconnected to the pc . It does do the same thing when is connected or whenit isn`t connected to the pc . What should i do ?
  • tokaresachin Feb 21, 2009
    how to trobale shoot procesar
  • 67 Answers
Make sure that the video card (if you have one) is firmly inserted into its slot.
Make sure that the connector from the monitor is firmly plugged into the CORRECT video slot on your back panel... Your video card may support more than one monitor and you may have it in the non default port.
Also make sure that the video driver is up to date or even installed.
As much as I hate to say it, there is also the possibility that the monitor is bad.
Posted on Mar 14, 2009
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
I have a 2002 Philips 150B2 and when I plug it in it doesn't turn on at all. The light for the power button doesn't even come on. Any suggestions on what is wrong with it. Thanks,
- Flickering screen
- Dim screen
- Slow start
Mar 11, 2015 | Philips Televison & Video
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
Ma acer aspire 5738z does not start at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 16, 2009 | Acer Aspire 5735 Notebook
Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Jan 05, 2009 | Computers & Internet
Monitor problem philips 170c 17" powers up shows pic for short time screen go's blank green light stays on can any 1 help thanks
it may be a problem with the playback of your monitor or just the pins at the back of the tube of your monitor. but first check your videocard. check the connections or uninstall the card, clean the contact points of your videocard and install it again.
Mar 14, 2008 | Computers & Internet
Philips 170C Monitor
i believe your monitor signal cable is bad or twisted.try straightening the data cable that connects to your cpu, if it doesn't work, replace the signal cable.
Feb 26, 2007 | Philips 170C4FS 17" LCD Monitor
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
