Question about Sony KP-53HS10 TV
TIMER/STANDBY LIGHT IS FLASHING - Sony KP-53HS10 TV
  • Sony Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
Jul 25, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Standby/timer light
check your menu settings to see if your off timer is activated or set.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The standby timer light is flashing
broken surface mount resistor of main power supply
Feb 09, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KP-53HS10 TV Logo
315 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
