Question about RCA RCR311B Remote Control
Cant find model p52937sg - RCA RCR311B Remote Control
  • 512 Answers
From "Wiki.Answers.com":
This is what worked for me:
Manual Code Search and Entry
1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Good Luck
Jack
Posted on Feb 22, 2009
My tv wont turn on
MY RCA HOME THEATER TV MODEL # P52937SG WONT TURN ON
WHAT MIGHT BE THE PROBLEM
Jan 06, 2013 | RCA P52926 52" Rear Projection Television
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
I need the manuel to my rca television model P52937SG
Go to this link and download your manual from the manual tab. http://www.retrevo.com/s/RCA-P52937SG-TVs-review-manual/id/402dj478/t/1-2/
Jun 08, 2009 | RCA Televison & Video
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA RCR311B Remote Control Logo
66 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
