Question about Ingram GeForce 2MX (32 MB) Graphic Card
Ingram Micro TFT-LCD monitor fault.. When my computer boots up the resolution is correct 1152 by 864 pixels but after a few seconds the resolution reverts back to 640x480 and I have to go in to screen settings to correct the problem.
  • 1,602 Answers
CHECK THE DRIVERS FOR THE SYSTEM, THE DRIVERS CAN BE CORRUPTED, OR MISSING PARTS OF THE PROGRAM.
THE BATTERY ON THE MOTHERBOARD IS FAILING
MONITOR IS STARTING TO FAIL
VIDEO CARD ERRORING OR AND THE VIDEO CARD IS HAVING IRQ AND DMA CONFLICKS
TRY TO USE THE SAME IRQ IS OR ANOTHER DEVICE WANT TO USE AND IT IS RESETTING THE MONITOR EVERY TIME
ROD
Posted on Feb 27, 2009
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
Set pixels too high. Now monitor won't display.
Native resolution: 1280 x 1024 @60Hz, That is what you need to set the PC video resolution to. Running XP? Boot up in safe mode (hit F8 while booting up), set the resolution to 640x 480, then reboot into normal mode, reset the resolution to 1280 x 1024 @60Hz.
Mar 22, 2010 | Acer V193w LCD Monitor
The sound is working but the screen flashes on and then goes off completely.
Try to boot you computer in safe mode (for low resolution) step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Coby 20" Flat Screen TFT LCD TV Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
Re Samsung Monitor
TFT means Thin Film Trangister. You are using LCD (liquid crystal dispaly) this means in lcd monitor use trangister on/off to create a pixel. you should give your monitor to repair at workshop for this problem. i don't know any workshop which located in your city. and about the expence it's all around rs 600 to 1000.
ok
bye
ramesh
Nov 13, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor Ingram Micro 1770 A/Mg 17" TFT-LCD
hey dude i have the same monitor the best resolution is 1280X1240 @ 60HZ
hope this helps
wez
Aug 08, 2008 | Ingram GeForce 2MX (32 MB) Graphic Card
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Computers & Internet Logo
152 people viewed this question
Top Ingram Computers & Internet Experts
micky dee
Pawan Dwivedi
Pawan Dwivedi
Diana Maltseva
Diana Maltseva
Are you an Ingram Computer and Internet Expert? Answer questions, earn points and help others
