What you do after you label the recording you play the dvd selecting the image and then play then stop it then select setup.
The instruction book doesn't follow through properly and I lost a dvd that way before I realized what it was after trying on a test DVD different things to get back to the setup screen that was supposed to have the finalize on it.
It's also a 1/4 inch to wide to fit on my shelf so it sits on top and blocks the remote sensor on the tv and makes tv control a bit difficult. The copies if you get them right at the fastest speed are very good though.
Many VCR's are protected from copy. Some start with that right away disabling the copy process others wait till thee film is half recorded. I understand some makes don't respect the copy proofing on tapes. I am not so experienced to say for sure that is so.
I can't find my manual and I would like to copy from vhs to dvd how do I make this happen
I have one i can copy and email...if you are interested - let me know (email is [email protected]) - i will say though...i agree with the above where the instructions are inadequate. I cannot get mine to finalize either.
Have a Magnavox and can\'t record my shows keep getting E26 and E45 not recordable in VR mode what does this mean
fix e26 error ------http://www.fixya.com/tags/e26/dvd_player...
fix e45 error----http://www.fixya.com/tags/e45_magnavox
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Finalize dvd
hit stop go to setup menu pops up scroll down to finalize and hit enter
SOURCE: hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
SOURCE: cAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
the manual failed to mention to push stop first. Than you can push set up and it works.......
