Question about Craftsman Garden
Keeps cutting out stop start
Craftsman lt 1000 42in cut 18hp antivib system.it keeps cut out all the time it fakes ages to mow
5 Suggested Answers
scott586
  • 41 Answers
SOURCE: It won't start with key; new fuse and new selinode
It may possibly be the seat switch. There is a little button under your seat, it is a safety mechanism. It's so the mower won't start without someone actually sitting on it, it will also shut off atuomatically if you fall off. If your good at wiring, and splicing, you can cut the wires and splice them together, and see if it starts. Hope this helps a bit.
Posted on Apr 30, 2009
  • 125 Answers
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
Posted on Jun 16, 2009
  • 10865 Answers
SOURCE: craftsman mower LT.1000 17.5
Check the air filter and replace it if it is dirty. Also, get a product at an auto parts store called seafoam, a carbeurator cleaner, and add it to your fuel at the rate of one ounce per gallon of fuel.
Posted on Jun 20, 2009
  • 7409 Answers
SOURCE: I have an 18hp 42inch cut Sears Craftsman, it will
check the gas cap vent little hole on top of cap clean with a pin-check and or replace air filter -check and or replace inline fuel filter if still not running correctly need to clean and repair carb
Posted on Mar 29, 2010
  • 403 Answers
SOURCE: i have a craftsman gt 5000 model 917.276220 runs
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Posted on Mar 08, 2011
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Craftsman lt 1000
Sounds like you installed the blades backwards, so the blunt edge of the blades are hitting the tall grass. This would cause the engine to bog down and almost die.
When replacing blades, always note the direction of the cutting edge. If possible, take a digital photograph of the old blades so you can refer to the picture so you can be sure of the direction.
If you go to Sears.com and search your model number, you should be able to find an owners manual that tells you how to install the blades.
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
I have an 18hp 42inch cut Sears Craftsman, it will crank, run a few minutes then cut off. Will crank back up just will not keep running. Dranied old gas, and changed spark plug, still doing the same thing.
Mar 29, 2010 | Craftsman Garden
Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
It won't start with key; new fuse and new selinode and the starter is fine craftsman riding lawnmower 42 in cut and 18hp
Apr 29, 2009 | Craftsman Garden
Garden Logo
118 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dwain Pippen
Jim Parker
Jim Parker
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
