Question about LG LS-L1210CL Mini Split Air Conditioner
Cant turn air con of with control
Air con works perfect,can not turn of with control.control turns on lights up but i think i need a code.
    Habit-Forming:
  • 109 Answers
If the remote is lg it haven't code the eye of the plate has burned
Posted on Feb 25, 2009
2004 chevy trailblazer when I turn on the air con my dash lighs for ABS and Brake come on, my cruise goes off and the air con will not work.
Have you had the vehicle checked for DTC'S - diagnostic trouble codes ? I would start there first . Battery , charging system all good ? What computer , the ABS has a control module all to it self . The Air con has a relay in the under hood fuse box controlled by the PCM / engine computer . If there is a problem with ABS , The EBCM - electronic brake control module will turn on ABS and the red brake light .
A low voltage condition could cause this problem , but I would expect more of the lights to be lit on the dash . Including the check engine light , battery light . This are not connected , Power or ground wise . Have the vehicle checked for codes , that should be the first place to start any diagnostic's always !
Dec 02, 2016 | 2004 Chevrolet TrailBlazer
Cruze - hot air from driver side and cold from passenger
Do yourself a favor an take it to repair shop before you mess it up or hurt yourself !
May 14, 2015 | Cars & Trucks
I dont know how to turn off the air con in the car, there is no button or dial to turn off
You should have either a "snow flake " looking button that willl turn it on and off. The other style is all controls with air conditioning are in blue. All functions with air conditioning is not colored blue. You will have air conditioning on automatically if you run the defrost.
May 08, 2015 | 2005 Nissan Almera 1.5
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Nissan pulsar n16 air con not working half a day randomly every few days. Air con works fine with cold air, then when I come to drive the car again either 1 hour or 6hours later it sometimes does not turn...
I had this same problem. I removed the aircon controller from the dash and found two dry solder joints on the back of the main circuit board. I resoldered these and it fixed the problem.
Oct 17, 2012 | Cars & Trucks
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
We have a 2007 CX7 and the air conditioning is not working well on either recirc or outside air in low ambient temps. When idling at the lights the air con becomes worse. There is no belt sqeal, and I dont...
When you have a moment pop the bonnet and look for the air con compressor run by a automotive belt on the side of the engine. Get the engine running at idle and then get someone else to turn the air con on whilst you watch the compressor. As the system is turned on the compressor clutch should engage and the unit should start turning, if this isn't happening there isn't enough pressure in the system (leak or just low on pressure) Get to your local air con guy and they will pressure test for leaks. Air con system is run on pressure, so that is really the issue you need to rectify
Note:- Manufacturers put the air con rad infront of the engine rad so stones get to that first, check the condition of the front rad through your bumper
Feb 19, 2011 | 2007 Mazda CX-7 Grand Touring
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Cruise control not working 1995 Shogun/Pajero/Montero
hi... I am facing the problem before. You need to change one control ring(yellow in colour)inside the steering.You have to open the steering n there is one yellow ring inside the steering box.That control ring quit expensive but sometime you can get it secondhand.thank you
Oct 02, 2008 | 1995 Mitsubishi Montero
LG LS-L1210CL Mini Split Air Conditioner Logo
275 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
