Question about Sony Ericsson J230i Cellular Phone
BATTERY CHARGING PROBLEM
SOME TIME BATTERY GET FULLL CHARGE & IF IT LOW THEN IT NEVER CHARGE.
  • Anonymous Mar 13, 2009
    cherger not full
    Guru:
  • 832 Answers
Hi there!
thanks for using Fixya.com!!
I suggest, try to change your battery to anew one. then charge it, if you are still facing the same problem, check the charger (but make sure you are using compatible and original charger ok?).
If you are experiencing the same problem though you are using the original charger, please change your charger to anew one, just to make sure that you do not have any problem with your phone.
then, if the same problem occurs, then perhaps you have a problem with phone itself.
Better, bring it to your technician, to have a better troubleshooting of your phone.
Hope this will help you, a simple solution, with a simple and handy troubleshooting.
Thanks! don't forget to rate me with my solution!
Posted on Feb 21, 2009
Battery will not charge
it means that something is wrong with your battery or its charger
Feb 02, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
My LG RD 6100 is showing charging but it is not actually charging.After removing charger it is showing that recharge the battery
It is best to get the charger checked with another phone as to confirm the case. In some cases the low regulation within the phone can efffect the charging circuit.
Also cross check the battery as if the battery is weak or had been not charged initially properly then it seems a suspect.
Dec 29, 2011 | Cell Phones
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
What is the battery life expectancy for the 2006 Buick Lucerne?
Battery life is a very complicated issue, there are TONS of factors. High temperature kills batteries, if the fluid goes low, that kills batteries. If you forget and leave lights on, and the battery goes totally dead, (totally dead, zippo, not anything) that kills batteries.
Alternator diodes that fail kills batteries. So 4 to 8 years is typical life IN ABSENCE of the above types of issues. My favorite battery is Interstate. They just work really well. Costco has great battery prices, bumpy for service... Really Dislike Sears die easy.
Oct 19, 2010 | 2006 Buick Lucerne
HI, Im BALAJI having DELL 1525 INSPIRON. My battery is not charging, it says PLUGGED IN NOT CHARGING. How to solve this issue.?
Replace the battery. If it shows that your are on A/C power and the battery is not charging then replace the battery. It is not holding a charge.
Leaving your laptop plugged in all the time will kill a battery quickly. You need to let the battery get very low then charge it to keep the battery fresh.
Apr 15, 2010 | Dell Inspiron 1525 Notebook
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
Charging
the batteries work on a principle of memory charge. hence if the charging cycle pattern is not followed ie full cycle of charge - discharge, this problem will arise.
you may need to change your battery only if the usage time is very low!
Jun 20, 2008 | Motorola Mobility V547 Cellular Phone
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Phone not charging
Last time I went to charge mobile phone, it would not charge. Phone comes up with low battery. Would it be the charger or the battery or phone?
Oct 08, 2007 | Lands Phones
Sony Ericsson J230i Cellular Phone Logo
161 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
