Question about ASUS VIA Apollo Pro Plus Chipset P2V-B Motherboard
Bios cheksum error
Not booting
  • ahmad_dollar Apr 15, 2009
    bios rom cheksum error
  • 530 Answers
Hi im josh in cebu phils. may i helped you? Friend you need to replace your cmos battery because The most common cause of a checksum error during the startup process is due to a faulty battery which is not providing sufficient power to the motherboard when the computer is off. However, motherboard malfunctions and viruses can also contribute to checksum errors. good luck.
Posted on Feb 21, 2009
My pc wont boot properly all i get is bootmgr is corrupt indows cannot boot, or i get cheksum error checksum not computed, i have tried the vista recovery disc it doesnt fix it, is there anything i can do...
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option. Type bootrec /fixboot ENTER if end up at the command prompt. It does the same thing.You could also run the install from repair.
Oct 16, 2012 | Computers & Internet
Bios cheksum error is what i get when i start my pc and the next i see is found drive a: make sure there is a bootdiskette and push enter. but when i do it he do not see my diskette . i do not know what...
disable the floppy drive from the bios if you don't use it. also you need to flash your bios newer ROM file version since your current bios is corrupted and when it compares the original checksum with the actual one it doesn't match, meaning your bios got corrupted.
you can get the latest bios files from your motherboard maker.
Mar 09, 2011 | ASUS Computers & Internet
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
Checksum Error after Bios Upgrade K7VZA
Have you tried resetting the CMOS? Often, after upgrading BIOS you need to clear the CMOS and re-setup to handle the new features. You should have a jumper to clear CMOS, or you can remove the power from the system and remove the battery for a few seconds to clear it.
Let me know if this clears up your issue.
Sep 19, 2009 | EliteGroup K7VZA Motherboard
My motherboard ringing long
can you tell me after beeping and cheksum error did boot your system or is stoping there?
if is stoping there see on the end of monitor a message lke pres f1 to continue.
presit and see is booting your operating system or not?
if yes all to do is to change your cmos bios onboard batery with new one.
if no then you have problem with your bios , try to flashit with new release of your bios.
Apr 09, 2009 | Biostar U8668 (U8668DV7) Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
ASUS VIA Apollo Pro Plus Chipset P2V-B Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
