Printer will not print anything I have an old Lexmark Jetprinter 1000. I have cleaned the nozzles and tried to print test page, but nothing prints. I have the black cartridge in machine. It did sit a while without being used. Is there any further cleaning I can do?
What do you mean? it prints blank pages?? I think you answered your own question.
You know a low end laser printer is less than $100 now? (buy an HP) and you will get about 20 times the yield from the toner cartridge vs. your inkjet for about the same money...cut your losses.
Posted on Feb 21, 2009
Lexmark 5000 won't print
attempt cleaning with alchol swab on the cartridges then clean mode and try and print test page
Dec 13, 2013 | Lexmark JetPrinter 5000 InkJet
I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
Jul 25, 2011 | Lexmark Z600 InkJet Printer
I ddon't know how to get the printer to recognize the color ink that I have installed. The printer will not print.
Make sure you are inserting the correct cartridge for your model. Try to clean the print cartridge nozzles using the computer. Load plain paper. Open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center). From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles. Try to print your file again and check it's properly printing now.
May 04, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
My lexmark z23 printer keeps leaving blots of ink or marks all over the pages that it prints
You may need to clean the nozzles on your cartridges. Please follow the instructions in this article in the Lexmark website on How to Unblock (Clean) the Cartridge Nozzles in the Lexmark Z13/Z23/Z33 Color Jetprinter.If problem continues, try to insert a different known working cartridge to determine if your other cartridge is faulty. Thanks.
Feb 23, 2011 | Lexmark Color JetPrinter Z23 InkJet
My black cartridge is good but i cannot print in black
Try to clean the nozzles on the black cartridge using a damp paper towel. How to Clean the Print Cartridge Nozzles and Contacts Manually. Then try to print to see if problem is resolved. You can also refer to these articles:
- How to Clean the Cartridges of the Lexmark Z615 Color Jetprinter in Windows - How to Clean the Cartridges of the Lexmark Z515/Z615 Color Jetprinter in Mac
I hope this information has been helpful. Thanks.
Feb 17, 2011 | Lexmark Z615 InkJet Printer
My Lexmark Z25 has been packed away for a few years. I have new cartridges but, the pages still print blank. It makes all the noises like it is printing but, nothing. Can't find original software for...
The blank pages is normally due to dried ink in the print head nozzles. Even by replacing the cartridges, the blockage remain.
You can clean the print head with some wet lint less (camera lens) paper soaked in iso-propyl alcohol.
If the blockage is wet, running a cleaning cycle a few times will normally remove the blockage after doing the above steps.
Feb 28, 2010 | Lexmark JetPrinter Z25 InkJet Color...
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
Jan 30, 2009 | Lexmark X5150 All-In-One InkJet Printer
3200 not printing
absolutely. that's a good idea, but unusual for what you're experiencing. The test page is generated locally, through memory on printer. The applications depend on the driver set, interpreting the print information.
Feb 26, 2008 | Lexmark Color JetPrinter 3200 InkJet
Lemark 1185 series won't print at all
Maybe the cartridges are dry. Try running a test page after running the maintenance nozzle cleaning.
Nov 09, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
160 people viewed this question
jasbo
jasbo
