Question about Copystar Ri-6230 Grayscale Copier
Copystar CS7530 saying sorter is not connected when it is, machine will not copy unless I detached sorter I was also told by a tech thatI may have a bad board. Please help
    President:
  • Copystar Master
  • 990 Answers
Hello sir; I don't think so, that not the board problem, try to push sorter unit close to the copier as tighten you can, if still not working, you have to check the switch has been actuated.
Posted on Feb 21, 2009
The sorter tray..where the copies are deposited...comes detached from the copier...it seems to be broken, you have to hold it in place or the normal vibrations of the copier causes it to detach..where can...
I belive that the part that you need is called Holding Tray Assembly and the part number is FG5-8666-000 and I think that you can find it at any Canon Partener.
Nov 15, 2010 | Canon NP 6035 Copier
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Infotec 5221dz when machine starts up it all
Check the sorter and exit part gears.Remove the sorter unit and make a copy.If the machine worked the problem is in the sorter unit,if not workwd the problem in the exit unit.If the sorter is defected you need to de-reassambly the unit,checked the mechanical components,sensors,motors and gears,and realignament the bin sections.For more information and suggestion please contact me.
Oct 10, 2009 | Ricoh Office Equipment & Supplies
Error E502-0000 CANON IR 2200
This problem generates from sorter/finisher ,try detached and disconnect the sorter unit from the machine
E502
Coming off of a sensor connector in an optional device is
detected:
•The door sensor, paper sort sensor, non-sort sensor, bin
outside paper sensor, staple position sensor, etc
Jun 30, 2009 | Canon imageRUNNER 2200
Toshiba;Can't make a copy
C54, lost communication with the sorter, Check the sorter/ finisher, make sure the connections are firmly seated, even try unplugging the sorter from the machine and replug it in.(Power Off first).
Restart machine
Hope this is of some help.
Ed
May 19, 2009 | Toshiba e-Studio 350 Copier
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
E524
loks to me like you have a problem... serious problem might be time to go buy a new machine. i know of the best place to get a fully functional machine. GUARANTEED (858) 292-4129 KCDS/BMU www.bmusd.com
Jul 24, 2008 | Canon NP 6050 Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Nothing is copying
E532 is a sorter problem. Have you replaced the staples recently? If so try to remove any jamed staples from the stable cartride and try to reinstall as shown on the inside of the soter front door. You can also try to turn the copier off and unplug the sorter and reattach it and turn on the power. See what happens, if that does not work and you don't really use the sorter, unplug it and detach it from the copier and make a exit tray and there you go. If you do use it call for service.
Feb 07, 2008 | Canon NP 6050 Copier
CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Jan 12, 2008 | Office Equipment & Supplies
Copystar Ri-6230 Grayscale Copier Logo
Top Copystar Office Equipment & Supplies Experts
NewYork kyocera HP...
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
