Question about Toshiba Satellite A105 Notebook
How to repair power lug into computer
Computer starts,runs for 30 seconds the fans do run. wont boot just shuts down
  • 544 Answers
Hi...
Hello their again if the problem is in your Power Plug i strongly suggest you to change it with new one than to repair with not sure.
for the reason it will be caused an addtional problem that may occur to your Laptop.
any problem jsut feel free to ask.
but please don't forget to rate our answer properly.
Posted on Feb 21, 2009
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20...
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Oct 21, 2013 | Acer Aspire One PC Notebook
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Mar 09, 2009 | Dell Inspiron 5160 Notebook
thank your for choosing Fixya.com
Please try to turn Off your unit and take off the battery after 5-10mins re install your battery and open your laptop.
please let me know if there any changes happens.
don't forget to rate our answers properly.
Feb 21, 2009 | Toshiba Satellite A105 Notebook
RE HP Pavillion ZE4800 Laptop When I switch on I here the fan start, the lights come on then it appears to shut down and re attempt to start again This occurs over and over and the PC never boots fully....
I have same notebook and similiar problem. Mine runs for 30 min then shuts off completely in like 20 seconds. I added a $10 usb powered laptop cooler pad and bingo, runs now for hours no problem. On all computers I know the cpu heat temperature has a threshold, if it goes too high it will shut off. I think my fan doesn't kick on fast enough to lower the temperature and cool the processor. On yours it may be a fan that doesn't work or is working at the wrong time and the circuit shuts off the system. Shouldn't be terribly expensive maybe $60 to repair from a good technician..good luck
Aug 15, 2008 | HP Computers & Internet
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
The PC doesn't completely boot up
u shoudl use xp cd and boot in formatt hard drive fresh install of your os
Jan 28, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
