Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have an error code 136 on fisher and paykel intuitive eco washing machine IW812
  • 144 Answers
I can talk you through fixing this in live chat
Posted on Mar 27, 2009
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
  • 351 Answers
SOURCE: fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Posted on Mar 03, 2008
ngfam1
  • 639 Answers
SOURCE: Washing Machine Broken
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
  • 251 Answers
SOURCE: Fisher & Paykel Washing
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
Posted on Jun 16, 2011
What is error code 130 fisher & Paykel intuitive eco IW812 ?
the R.P.S or rotory postition sensor is faulty or the connections are corroded
Jun 29, 2014 | Fisher and Paykel IWL12 Top Load Washer
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive Eco. FAULT 136
Washing Machines Logo
890 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
