Question about Epson Stylus Photo R220 InkJet Printer
When i try to reset counter, it comes up communications error
When i try to reset the counter on my epson photo r220 it displays a communications error. can you help?
  • Epson Master
  • 419 Answers
A communications error usually means that there's a problem with the connection between the printer and the computer.
This could be because of a duff USB cable or something pulling on (and damaging) the connections. However I've also heard of this behaviour when using the SSC utility in an attempt to reset the waste ink counter which I'm guessing is what you're trying to do.
If you are based in the USA I'd recommend filling out the form for this utility:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
It does invalidate your warranty but the R220 is that old that you won't have anyway.
If that doesn't work then you could try looking for an adjustment utility but be warned they are a lot more complex and it's easy to bork your printer if you're now careful.
Keywords: "eserviceinfo r220 adjustment utility"
Posted on Feb 21, 2009
  • Martin Smallridge
    Martin Smallridge Feb 21, 2009
    Blimey... typo hell today...
    [CORRECTION]
    It does invalidate your warranty but the R220 is that old that you won't have ONE anyway.
    If
    printer if you're NOT careful
    [/CORRECTION]
    More sleep for me in future :)
  • Martin Smallridge
    Martin Smallridge Feb 22, 2009
    The R220 doesn't have a firewire interface.. USB only.
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
How to reset counter epson r220
Download and install the latest version of SSC Service Utility for Epson. You can download it from this site - http://www.ssclg.com/epsone.shtml
Jun 06, 2011 | Epson Stylus Photo R220 InkJet Printer
2 red flashing lights on epson r220 printer
Normally indicates the ink counter needs resetting the following utility will do it make sure you read AND FULLY UNDERSTAND THE INSTRUCTIONS.
Aug 11, 2010 | Epson Stylus R220 Photo Printer
We have problem in reset counter and reset waste ink pad for eposn printer r 230 pls give solution for reset counter setup and further process
The SSC Service Utility prog supports the R230.
Download link at bottom gf page.
Feb 12, 2010 | Epson Stylus Photo R220 InkJet Printer
How do you change or clean the Epson R220 waste ink pad, are there photos or diagrams on how to do this? Thanks.
you need to download adjustment program of this printer of you can download "SSC Service program " by searching google.
you need to reset protection counter.
Sk Abdus Sabur
Jan 02, 2010 | Epson Stylus R220 Photo Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Jul 30, 2009 | Epson Stylus Photo R220 InkJet Printer
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
Aug 23, 2008 | Epson PictureMate (C11C556001) InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
637 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
