Question about Philips HTS3450 System
No Power From My Reciever
I have a Philiips hts 3450 surround sound system. i have had it for about a year or so. the power in my house suddenly surged one time n my reciever was plugged in, but was not powered on. it took the hit. the red light on ther reciever stayed lit, but wouldnt power off. so when i unplugged it, it was shot. i recently plugged it up and it made a light "clicking" noise until i unplugged it. is it still some life in this? because, the way this reciever is set up. i dont think i can use any other reciever. if i can, what can i use. but i'd rather revive the one i got because the speakers would be shot!
  • timtlc Apr 07, 2009
    Used my HTS3555 last night was working fine. Set up the timer to turn off the unit and tv. Woke up, no power. Will not eject the DVD. Tried Unplugging.
    Power light cycles on and off a little (dully) a few times after the unit is unplugged.
  • Anonymous Apr 08, 2009
    Power is on but no sound.... All other functions seem OK
    Scholar:
  • 144 Answers
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Posted on Apr 17, 2009
Repair Philips HTS 3450
What exactly is the issue? no deep bass? pffft instead of woof?! low volume?
Info needed,
Sep 12, 2017 | Philips HTS3450 System
Why won't my TV sound go through the Hts 3450?
Wide open one here. Is your tv coming in direct from the wall or do you have a cable/digital box that you need to get the signal from? If you have a box then make sure you are plugged into the audio out on the box and on the HTS you are on the audio in. There will be a left and right. If you have the sound to your tv then you can plug into the audio out on your tv and again plug into your audio in on your box. If your tv has an option for external speakers then you need to make that adjustment on the audio menu on your tv. Also make sure that the proper channel is selected on your HTS and that your audio output matches your selection. Hope this helps but I will keep an eye out for further posts.
Nov 12, 2012 | Philips HTS3450 System
I cant get the surround sound to work with the tv stations but it will work with DVDs
Not much detail to work with here. Your cable box (?) should have a digital audio output. Use it if your HTS has an input for it. Otherwise, analog audio from the box or TV won't produce true surround, but most HTS can simulate it.
Jan 10, 2010 | Panasonic Home Theater System System
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
I have an RCA RT2500 audio-video surround sound receiver about 10 years old. For the second time in its life, a power fluctuation has knocked it out of service. The standby light comes on, but no power to...
Hold down the power button and unplug the unit. Now release the power button. Plug the unit back into the wall. Now press the button. The system should power up.
Oct 22, 2009 | RCA RT2500 System
HTS 3450 subwoffer off
I have a similar problem. I inspected the power board and found IC901 burned completely. I cannot find out the part number and have tried to get a reply from phillips but have not heard back from them. Anyone have a schematic or can give me the part # of IC901?
Sep 06, 2008 | Philips HTS3450 System
Email id
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jun 12, 2008 | Philips HTS3450 System
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Feb 02, 2008 | Pioneer HTS-GS1 Theater System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Philips HTS3450 System Logo
312 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
