Question about GE WBSE2090A Top Load Washer
Water does not empty from tub - GE WBSE2090A Top Load Washer
  • kimspouse Mar 01, 2009
    water does not empty from tub. The lights go on to indicate spin and it has a slight hum, but will not empty or spin
  • GE Master
  • 3,361 Answers
Unplug the washer.
Remove the front panel. putty knife needed.
Remove the drain pump and clean it out as well as the drain hose from the tub to the pump.
If they are not blocked replace the pump motor.
Posted on Feb 21, 2009
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
We have a newer Whirlpool Cabrio washer and no matter how many clothes we put into it we always get a ol error.
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Water appears to collect in the tub when the machine is not in us
This is caused by a faulty inlet valve solenoid. It is allowing water to run into the tub. The solenoids can be tested using a multimeter for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need replaced. See the attached photo for reference. Hope this helped and best wishes.
Aug 03, 2009 | Washing Machines
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Tub in washer empties as fast as the water runs into tub
ck height of drain needs to be at least 30-36 inches from floor also be sure drain hose is only 6-8 inches into standpipe be sure there is a small air gap between drain hose and standpipe.. hose needs to fit loosely into standpipe or siphoning may occur
Aug 25, 2008 | Frigidaire GLET1031 Top Load Stacked...
No Ice on GE Side by SIde -TFX25JRYF-WW
Usually there is a big metal frame-switch that controls the flow of water. It is located right above the ice tub. If your ice tub is full the ice cubes push this metal switch up so as to stop water supply. If you remove the ice tub out, chances are that you have accidentally pushed the metal switch all the way up until it clicks and stays there. In this position, the ice mold water flow is permanently stopped.
Insert the tub again in its position slowly. Before fully inserting it, pull the metal switch down inside the empty tub. With the switch down, insert the ice tub back into position.
If that does not apply for your refridgerator, look for a similar water flow switch to turn back on the water flow.
Hope this helps
Mar 07, 2008 | Refrigerators
GE WBSE2090A Top Load Washer Logo
172 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
