Admiral washing machine is not spinning.
My Admiral washing machine is not spinning. All other functions are fine.
  • Anonymous Feb 21, 2009
    washing machine fills up with water and that's it...does not spin or anything else.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral washer will agitate but will not spin dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
The admiral washing machine works fine except on the spin cycle it wabbles wildly, like the clothes are loaded on one side. but does it even while washer is empty
At its best this washer is a beast in the spin cycle. The machine must be mounted on a cement floor. It is written in the unpacking instructions. Check all springs, machine must be level. If all checks out replace snubber ring or adjust by centering snubber ring Mounted unde the transmission base.
Jun 22, 2009 | Maytag Admiral AAV7000A
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washer spins agitates, but will not drain
Possible your outlet filter is blocked; find out where it is from your manual, clean it out and re-fit. Also try the spin only function to see if it drains.
Jun 13, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
