Question about Samsung MMZJ8DABRH CD Shelf System
I have a shelf system samsung MM-zj6, its out of order, doesn´t turn on of the source power, the display is off always, is black, what I can do? please help me. Thank you. Armando.
  • Anonymous Mar 23, 2009
    I have the same problem. Please help
Hi Armando, I guess you chucked it in the bin by now, but I just fixed exactly this problem on my MM-ZJ6. It is caused by capacitor RC7 (10uF) going open circuit which puts a huge ripple on the "Power Sens" line causing a reset pulse to go to the microprocessor every 50msec, resulting in it never starting.
To find RC7, remove the right hand side panel and look at the very bottom front of the large pcb. It is the smaller of the two located there. To change it, unclip the rear panel and angle it back slightly. You may find it easier if you remove the CD unit first.
Colin.
Posted on Nov 29, 2010
  • 3 more comments
  • Mazeas Pierre Jan 08, 2013
    08/01/2013 bonjour de France - merci Colin : ta solution m'a permis de remettre mon MM-ZJ6 en fonctionnement
    08/01/1013 Bonjour de France ... Merci Colin : ta solution m'a permis de remettre mon MM-ZJ6 en fonction
  • ervinbur
    ervinbur Mar 16, 2013
    Thank you Colin! Thank you very much! You saved me from buying another amplifier.
  • Andrew Whittingham Dec 02, 2013
    I have the same problem and went to buy some 10uF capacitors but the supplier said I need to know the operational voltage. Any ideas ? asper y
  • colinwray Feb 07, 2014
    I don't remember, but it is written on the side. Probably 50v. Also be careful to get it the right way round, check the +ve and -ve marks before removing it.
After plugging the hdmi cable, we have the sound but no video
Some ideas:
  • Make sure the correct input is selected for your display device.
  • You may need to change the video out setting on your video source device (Blu Ray player, cable box, etc) to turn on the HDMI output port. See the video source's manual.
  • Devices connected to HDMI are sometimes picky about the order they turn on. Try turning off the video source and video device, then turn on the video source, wait a few seconds, then turn on the display. If that doesn't work, try reversing the order that they are turned on. If this is the problem, you can buy a universal remote, like the Harmony, that will start devices in a specified order.
Feb 12, 2012 | Panasonic DMPBD655 Player
I'd like to use my canton DSS 303 as a computer speaker and i don't know whether i can or how
It doesn't know or care what feeds it if the interface is compatible.
http://hifi-ring.com/2008/03/30/canton_dss-303_digital_sound_station_for_ipod.html
" ...via the 3.5mm line-in connection". Find a stereo cable that matches whatever you have on the PC end and 3.5 mm on the DSS.
Sep 09, 2011 | Canton DSS 303 Mutimedia Series Audio...
I have got a Sony CMT-EX100 Micro System. When I touch the OPEN/CLOSE-button on the top, the system doesn't open. I opened the system and it seems that the magnetic disc-holder holds the disc-tray too...
This problem is easily repaired! The belt that drives the mechanism is worn out (relaxed) and slides on the motor pulley. Just open the device (from the bottom and then drag the body up by removing the edges). You have to put a new belt section ø 35 mm 1 mm and the unit will work again.
(hello from France)
Jun 05, 2011 | Sony CMT-EX100 CD Shelf System
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
MY REMOTE ALWAYS SHOWS ME REM506....
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
May 07, 2009 | RCA RS2100 Shelf System
SCREEN PROBLEMS
Try unplugging unit for 24 hours then, retry. Unit may also have problem in standby circuit, have serviced
May 06, 2008 | Kenwood HM-331 Shelf System
Protect
Hi Andy,
Does your unit go into protect mode without speakers connected?.
Jango
Mar 03, 2008 | JVC HX-D7 Shelf System
Press Power Protect
Always be solved replace him the audio amplifier IC
Dec 30, 2007 | Sony MHC-GS300AV CD Shelf System
Sony lbt w300
To isolate the source of the problem disconnect all speakers and turn on the unit, if it works that means that you have to check cables and speakers. If the problem remains that means the problem is with the unit. Professional technician is required: The problem is at the power output section (Defective out put IC or Voltage error?) Good Luck Toufic Malek
Sep 04, 2007 | Sony LBT-W300 Shelf System
Error e-20. Doesn´t Work anything related to the Cd Players.
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Jul 28, 2007 | Nakamichi SoundSpace 9 CD Shelf System
Samsung MMZJ8DABRH CD Shelf System Logo
666 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
