I have an Admiral 6005 washing machine. Model A6738-010. S/N 021380 Recently it stopped spinning on the spin cycle. The bowl appears to go round when filling with water. The clothes collect on one side and tightly around the agitator. The washing is now very heavy & very wet.
  • allancooperh Feb 21, 2009
    I'll try unplugging it. All the other functions of the timer are good. The load only shifts on the spin cycle. Is it possible a solinoid that engages the bowl is not functioning properly?
  • Priya darshan May 11, 2010
    HI,
    IF it doesn't spin then check these:
    • Test the lid
      switch
    • Test the timer control
    • Test the centrifugal switch
    • Test the water
      level switch
    • Inspect the motor
      coupler
    • Inspect the drive belt (belt drive only)
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
  • 217 Answers
Check the following link it describes all the issues with the washing machine and how to repair it
Repair Washing Machine
Posted on Feb 21, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description, either a drain problem or motor problem:
  • check the drain area, clean the filter, sump/bowl, impeller, drain pump, valve and drain hose. An easy/doable but messy.;
  • the speed of the motor is not sufficient to evenly distribute the load. Components to check would be the starting capacitor and/or the windings of the motor.
The above requires a bit of familiarity with electrical components & circuitry as well as use of a DVM. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would be to seek the services of a qualified professional.
Additionally, you could try to unplug the unit for an extended period of time to revert to factory defaults.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 21, 2009
    Hi again,
    Appreciate the postback. For some reason Admiral 6005 and A6738 does not show in any washing machine database, could you pls confirm exact model number. Incidentally, normally there is a tech sheet somewhere in the machine itself, either at any of the panels/covers (such as the kick panel) or in under the control panel cover. The tech sheet also includes a wiring diagram and an exploded parts diagram.
    Genius:
  • 3,422 Answers
HI,
Clothes are too wet after spin cycle
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the water level switch
  • Inspect the motor coupler
  • Test the motor
  • Priya darshan Feb 21, 2009
    HI,
    Clothes
    Drain:
    • Inspect the water
      pump
    Spin:
    • Test the lid
      switch
    • Test the water
      level switch
    • Inspect the motor
      coupler
    • Test the motor
    Please click on the blue coloured links for more info.
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Dec 10, 2009 | Admiral AW22 Top Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
