Question about Dishwashers
Never ending dishwasher
My dishwasher is not finishing its cylce after 2 hours its still washing.
  • Maria Cousineau Jan 01, 2012
    I am having this same problem with my Kitchenaid. And turning off the heated cycle didnt help. The last time the repair guy came out, he retrieved some papers from under the machine and hit a series of buttons to "reset" the machine. Not only can I not find the paper (to tell me the reset steps), I cannot recall what buttons he hit in what order. Anyone know?
  • 3,361 Answers
De-select all hi temp options and try it.
If it works you have a bad hi-temp thermostat.
Posted on Feb 21, 2009
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
The blue indicator light will no longer come on at the end of the cylce
Hello Loucinda Stanley - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle let it run and then the indicator light should display at the end of the cycle. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 16, 2013 | Electrolux 24 in. EDW5500DSS Stainless...
Panel is switching back between 6 and F at the end of the cylce
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
Above is a link for the error codes and what they mean.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is your service and repair manual. with troubleshooting steps, to isolate your issue.
Jun 22, 2010 | Kenmore HE2 Plus Front Load Washer
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
How long does it take to do a wash in a dishwasher?
it sometimes depends on the machine most unit that are electronic that do not display times can run for up to 2 to 21/2 hours from start to finish
Feb 23, 2010 | Dishwashers
Cycle is taking longer then it should
Check your household water temperature. It should be 120 degrees or better at the kitchen faucet. The dishwasher may be trying to heat the water to a predetermined temperature before advancing the timer. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
