Question about Canon DR-2580C Path-Through Scanner
The cannon DR 2580-C resinstalled to new computer
I just reformatted my computer yesterday. This cannon scanner was working very well as of yesterday. But, after I reinstalled the software to the new fformatted computer (WindowXP), I click the capture 3.0 icon, then go to Scan, then choose "page to file", there is no device found, it said:cannot locate the device, check cable and power.
The power and cable are connected very well. Can you tell me which step I am missing when I reinstalled the software? I installed the capture perfection, Driver, Jobtool, it is all automatic installed when I click the "setup".
  • 490 Answers
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
S. Mohan, Chennai, India
Posted on Feb 24, 2009
Are you able to send me a driver for: Cannon DR 5080C Cannon DR 4010C rgds BT
You can get the correct drivers from Canon for free. Get teh correct one for yoru printer and OS.
Oct 27, 2010 | Canon DR 5080C Path-Through Scanner
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
Apr 26, 2010 | Epson 2580 Perfection Photo Scanner
I have an epson 2580 it now produces somewhat
The only way you're going to know if it's the scanner or the driver for sure is to install it on say an XP machine and see what results you get. If it's still dark, it's the scanner, if not, it's the driver.
Dec 15, 2009 | Epson 2580 Perfection Photo Scanner
Scanner not found
Have you installed ISIS/TWAIN Drivers? If not download item 4 from this link http://software.canon-europe.com/products/0010203.asp
If you are using Vista, you must install corresponding drivers.
Apr 12, 2009 | Canon DR-5010C Scanner
Cannon MultiPass MP730 printer/scanner is offline
Try reinstalling the software if on canon.com website.
Apr 02, 2009 | Cannon EOS 50D Digital Camera
Canon DR 1210 C Communication error
After uninstallin you need to reboot the computer and install as per procedure. this should help.
S. Mohan
Sep 09, 2008 | Canon DR-1210C Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Word 2003 'save as' problem
It is possible that some .dll files in the OS are corrupted. Try running scandisk.
S. Mohan
Oct 22, 2007 | Canon DR-2580C Path-Through Scanner
Canon DR-2580C Path-Through Scanner Logo
1,235 people viewed this question
old marine
old marine
