Question about Philips HTS3440/37 System
I have the philips hts3440/37 none of the speakers work.
I have a surround sound system. ive hooked it all up and i have picture but no sound. all my speakers go though the big subwoofer speaker. so i was wondering if maybe the sub had a fuse in it somewhere that could have blown and is causing the sound not to work.
  • 8,596 Answers
Doubtful that it is as serious as a fuse, unless it was working before and now it's not.
Are you getting no sound when watching DVD's? Try adjusting the volume on the home theater system - press the SURR button until it says "Dolby" or something like that.
Make sure it is connected like this:
i have the philips hts3440/37 none of the speakers - 060120163459_10528.gif
Posted on Feb 21, 2009
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
How can i get my surround sound working for my ps3 i have a philips hts3357 home cinema please help
Hook the ps3 into the tv. Hook the T.V out going to the surround sound system and you should get your game sounds out of your surround sound.
Mar 01, 2011 | Philips HTS3357/05 Theater System
Philips lx3000d surround sound system. centre
cross check the audio device settings. check the audio level of each channels.
Also try exchanging the speakers whether the speaker itself is damaged.
Hope this helped.
Jan 05, 2010 | Philips LX3000D System
I HAVE GOOD PICTURE NO SOUND..SOUND WORKS IF I HOOK UP STEREO..
You may have to get into the customer menu..Locate audio speakers on the menu and see internal speakers on/off....Could be this simple....But try.......On the other hand if you shorted the connections to the surround sound speakers and you would know by the howl, You audio output IC is cooked! And this is located on the small signal board. Hope for the best and expect the worst!
Sep 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Need help with my suround sound system
try wiggling the cords.i think it's open from the inside of the cord.sometimes attaching and pulling cords is the cause of no sound at all.check your cords for open.you can use a battery and a small lamp and wires.make a circuit of a lamp.then, get one wire from the small flashbulb and use it as a probe.the wire from the battery is the other.hook it up to your cords touching the one end ,like completing the circuit.if the bulb lights up it means it's ok and if not, your cord is open.
May 15, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
Only 2 of my 5 speakers are working
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Apr 30, 2007 | Philips MX3700D Digital Surround Sound...
Philips HTS3440/37 System Logo
819 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
