Question about AKG K 26 P Consumer Headphones
Severed cord on my wonderful headhones AKG K24P.
I thought it would be simple matter of exposing the wiring of the left and right severed cords, then solder and re-sheath each with insulating tape. The headphones did not operate.
I did observe that the left cord wiring when exposed had a extremely fine red insulated wire running through the cord. I exposed the fine inner wire of this red wire and rejoined the break. Still no sound from the headphones. Can anyone help please. I am pretty handy and normally can solve and repair. This has me beat. Thanks, Eric
  • 1 more comment
  • ericbanks Feb 23, 2009
    http://www.fixya.com/users/shantomken
    Thank you Shantomken. Fully understand. I will attempt the repair as you have outlined
    Regards,
    Eric
  • Anonymous Apr 22, 2009
    What if the other wire I want to connect to has 3 wires?
    Is it necessary for all wires to be connected to get any sound at all?
    I have been playing around with contacting wires in every combination and have gotten no sound at all- not even a scratching or hissing to make me think I'm on the right track.
    It is likely that the wires are plastic coated, but I would have thought twisting and scratching the wires together would at least remove enough of the plastic for even a faint pop.
  • Anonymous Mar 16, 2014
    There are two wires one bare copper the other red insulated I think. There are two connection sites on the ear pad labeled + and -. Which wire is +? Thank you in advance.
  • 3 Answers
It sounds like you actually have 2 wires closely wrapped together. They are very fine and you have to make sure that you have separated all of the wires from each other. Generally you will have a red wire and a copper colored wire for the right side and blue (or green) and copper colored for the left side. you need to make sure that none of these little wires are still mixed with each other, otherwise you have a dead short and the speaker will not work. The insulation is very thin so there is no need to strip it, the insulation will burn off when the solder is applied
Posted on Feb 21, 2009
How do i replace the end of an electrical cord that has been cut off
Purchase a new 3 conductor End - Note*** Connection procedure will be the same for either the Female or Male end...
  • Carefully cut around the sheathing being mindful to not cut into the individual wires sheathing.
  • Then peel away about 1.5", exposing 3 individual wires
  • Now, strip back about .50" of sheathing from each wire
  • Twist bare wires so individual strands are tight
  • Separate the cord end (many different varieties) and insert wires into a hole, securing nut, etc, to bring into proximity of connection lugs.
    • Black wire onto 'Gold' screw
    • White wire onto 'Silver' screw
    • Green wire onto 'Green' screw
  • Reattach in reverse order
May 30, 2015 | Generic 50ft 163 300 Volt Extention...
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
It would be the easiest way, attaching a male plug to the end of the severed cord so it can be used with an extension from the power outlet. Safe too if you duplicate the wires in the old portion, as the cleaner may or may not be earthed.
Oct 13, 2014 | Vacuums
Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Oct 27, 2009 | Bose on-ear TriPort Headphones
Cord severed on submersible pump
Assuming you are not able to reconnect the cord at the junction with the pump, you can use silicone filled wire splices to repair the cord. These are used for submerged well pumps and consist of a heat shrink splice tube that has a silicone liner. You slip the sleeve over the wire, solder the ends of the wires together and center the joint in the sleeve. Then you use a heat gun to shrink the sleeve. It melts and compresses the silicone into a waterproof seal. A separate sleeve is used for each of the wires in the cord. If not available at a hardware store or Home Depot or Lowes you should be able to get them from an electrical or plumbing supply house.
Aug 14, 2009 | Garden
Need help with changing the dryer cord from a 3 prong to a 4 prong cord.
The 4 prong dryer cord white wire goes to the center terminal connection. The green wire goes to a external ground(any screw) outside the terminal cover. Red and black wires go right and left of the white center wire. Does not matter which is right or left.
Jun 05, 2009 | Crosley Dryers
Won't start
After reading some posts on this site, we checked the power cord since someone else experienced the same problem. Whalah! Problem fixed - our cord was severed and one line inside the cord was also severed. Called the store where we purchased it and they are coming out this morning to switch this machine out.
What a great website!
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Power adapter wire too short to reach outlet.
It is tough to find the right power adaptor with the "right" length cord. Your best bet would be to use an electrical extention cord for the added length you need. "if you can't get the adaptor to the outlet....... take the outlet to the adaptor' !!!!
Dec 26, 2008 | Thomson GE 2.4 GHZ Corded Base / Cordless...
Replacing the electrical cord on a Roper Refrigerator
I may be able to assist...If you haven't done so already..UNPLUG The cord. Now, depending on where the wire was severed, will impact the degree of difficulty in reinstalling it.
I suggest that you position the fridge so that you can access the place where the cord actually goes into the fridge.
I assume that the cord passes thru a cable feedthru of some kind in the back so you may want to follow that into the fridge.
If the cord was severed outside the fridge you could simply join the 3 wires together as an inline connection ( making sure to keep the supply line, neutral and ground wires bonded to their corresponding ones ... meaning ground wire to ground wire, neutral to neutral and supply line to supply line... line may sometimes be referred to as the 'hot' feed.
If the cord was svered off internal to the fridge, try these steps..
You will probably need to remove an access panel on the back to see where the power cable is routed within the fridge. Once located, you will need to find where that cord was severed when it was pulled out. There should be 3 wires coming into the fridge from the power cord. I assume it came with a standard three prong plug that is compatible with a wall socket. You will have to identify which wire is which on the cord. It helps if you have a continuity meter or ohm meter for this. First, identify which of the 3 wires is bonded to the round terminal of the plug ( that would be your ground wire) That wire should be secured to the fridge frame with a bare screw of some sort. You may be able to trace the cord inside the fridge back to that point or you may be able to reattach the severed wire together using wire nuts to keep the wires joined together and electrically insulated from surrounding surfaces. Remember that it is critical to maintain the same point to point wire configuration as it came with. As a general rule of thumb, a bare copper wire or green insulated wire is typically the ground wire. Depending on the cord type, black insulated wire is normally the supply or HOT feed, and white is typically the neutral line. You may have different color insulation on your wires ( especially if it is a molded cable assembly ) so make sure you verify which wire comes from which terminal on the plug. ( round terminal on plug is ground, the longer of the two ( if it is a polarized plug would be your neutral and the shorter terminal would be the supply line. If unsure, get professional assistance. Hope this helps...
Aug 06, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
AKG K 26 P Consumer Headphones Logo
529 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
