Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My Book 500GB does not load
My hard drive was working fine, but one day when i plugged it in, the light goes on but it just doesnt load and read on my computer. Is there anything i could do so i don't loose everything saved on it?
  • 3 Answers
Ok here is your solution on ALL of these external mybooks by Western Digital... If you are getting a device not recognised, and can't get to your disk in any other way what has happened is it's generic power and usb card that is connected to the hard drive inside it's plastic box has gone out. These western digital essential edition drives which look sealed actually have some tabs on the shiny plastic case about 1 inch in from the front on the bottom. Just put the tip of a streight screwdriver into the cooling slots. Gently pull up and back on the screwdriver bending the slotted area by the outer **** shaped cover 1 inch from the rounded front. Pull up and towards the back. Once you have both sides of the bottom front released, then try to gently pry the bottom center up above the side of the ****. Because there are 4 tabs (2 on each side) that extend down from the main housing with the cooler holes that just rest in a track that is in the inside of the outer shiny **** shell. Then repeat for the top of the drive unit. After a little work you can remove it sliding it all out of the back. Once the outer shell is off, you can pull the drive out with the SATA to power and USB card connected to the drive. There is a metal housing over this card. Remove the 2 screws on the top of the metal housing of the usb&power. Once removed the bad card can be slid down of the drive. You can then just plug the drive in in any SATA port with SATA power inside your computer. Or just buy an external drive housing from tigerdirect or newegg for $20 which will make any sata drive to an USB External. What can I say, Western Digital has crappy cards. I only found this out by my having 2 My Books. 1 worked, and one fowled.. So I took them both apart. Better than loosing my data seeing how they were my backup drives...
Posted on Feb 21, 2009
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
Laptop wont stay on
ok. first insert the power cable and remove the battery and try starting the computer. If it still goes off when windows is loading then its a virus and reinstalling the windows would be the solution but if it continues to windows then its from the battery.
Aug 02, 2010 | Averatec Sotec 3120X, 3120V hard drive...
Will not complete boot up into windows 2000. Has worked fine for years, other day there was a power outage and next day we came in and the server was blinking at the final stage of boot process before...
I would recommend you boot to your 2000 CD, load the RAID driver for the CERC, and go to Recovery Console and perform a CHKDSK /R and FIXBOOT at the command line. Sounds to me as if Windows has been damaged. Is the power light amber or blue?
Apr 01, 2010 | Dell PowerEdge 1800 Server
I can't run dvd's, cd's or any software! What do i do? did my hard drive crash??? I had to run a system recovery on my computer. I was able to up load from my software disks. But then one day my hard...
Your hard drive doesnt read your software disks per-ce.
Check the device manager for faults. If you find any, you must resolve them. Sometimes the best resolution is to delete the device and allow windows to reinstall them.
If you need additional assistance with this, let me know.
a
Oct 05, 2009 | Computers & Internet
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
External hard drive failure
Try to use Computer Management, goto Start> Control Panel> Administrative Tools> Computer management> Disk Management. select volume or harddrive available where you want to open. If the harddrive not yet assigned a drive letter; please assign it and apply. Then right click and explore.
Hope this will be helpful, please rate my solution SOLVED!
Best regards,
Philip
Nov 20, 2007 | SmartDisk FireLite 60 GB Hard Drive
Drive not working at all, Nada
Hello Wolf, Ive had the same problem with mine. There doesnt seem to be an explanation as to why it stopped working. Unfortunately It most likely means that it is broken.
However a useful tip i was givin is if you take the drive out of the casing and attach it directly to your computer (as the slave or master drive) it still doesnt load up then you know for sure that its had it. Otherwise it should load up fine then you just need to transfer the data and get a new drive.
Hope this helps. SM
Nov 05, 2007 | LaCie F.A. Porsche (301177) Hard Drive
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
325 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
