Question about Philips Magnavox Learning Universal Remote
I need the code to program my aventura tv,with my phillips universal.
SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
Posted on Jan 09, 2008
SOURCE: jensen universal JER323
jensen codes to dvd panasonic
Posted on Jul 18, 2008
SOURCE: Rrmote control codes
i need the code for philips universal remote i lose the code
Posted on Oct 12, 2008
prawinmv22
  • 106 Answers
SOURCE: I need the code to program a phillips universal remote
hi...
use the following link to see the remote code list for all kinds.....hope this helps you always.....
http://www.universal-remote.net/philipsmagnavox.html
if this has helped you then rate for my solution......
thank you.....
Posted on Jul 19, 2009
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Need to program my phillips universal remote CL035A to my Sylvania TV
Look in the manual of your
Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual.
If you can locate Sylamia, follow instrucions for unspecified device.
You don't have a manual?
How to Program Philips Remote Control Without the Codes eHow
Jun 19, 2015 | Sylvania Televison & Video
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
I have a phillips universal remote and need the program code for a insignis tv
i have a philips universal remote control and need the program code for a samsung tv i also forgot hot to program it
Nov 11, 2009 | Philips Universal PH301S Remote Control
NEED CODES for my rca tv
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Try searching the Philips site for a later code list and if that doesn't help, try the other Funai/Philips/Magnavox brands:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Aug 07, 2009 | Philips Magnavox Learning Universal Remote
Need codes and instructions for Radio Shack 3 in one remote programming
First, you need to realize that there is no such thing as a 'universal remote.'  At best, they are multi-brand remotes.
You might get lucky if you try any codes you have (or can retrieve from the Tandy website) if you check these brands too:
They are all made by Funai, one of the worst manufacturers in Asia.
May 17, 2009 | Durabrand DWT1905 TV
Need remote code for Phillips
tescos have the phone numbers for tech help desks at phillips and may have some codes
Mar 26, 2009 | Universal Remote Control Remote Control
I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips Magnavox Learning Universal Remote Logo
1,090 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
