Question about SanDisk Sansa Fuze MP3 Player
I was deleting a song off my sansa Fuze, and it shut off!!!
I was deleting a song off my sansa Fuze, and it just shut off. I tried holding the home button for 30 seconeds & consistantly been doing this over and over with each button. I've tried to recharge it. Sync it. Any idea that really came up as somthing as commen scence I did. I 've had less then 2 months!
  • Anonymous Feb 28, 2009
    Tried to delete a song and it change to a white screen completely inoperable. Held the power button for 13 seconds until it turned off. Turned it back on all of the song ratings I added in the prior session did not save. Tried delete again same thing happened, except upon powering up it went directly to the white screen. This continued until I gave up. The next moring it was working for half the day and it happened again so I took it back and got another one. I suggest making a back up file for you sansa on your computer and updated it as often as you make changes.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
Sansa fuze just froze when i hit skip to listen to another song. please help!
Not to worry, your sansa just hung up , Please look out for the small hole on the sansa for resetting the device, use a small office pin to depress and hold on. The ipod will be reset now and you must be able to continue playing. Connect you sansa to a PC and check out the loaded files. scan them with an antivirus, delete if any corrupt ones. I hope this clear up the issue. Good day
Jul 07, 2010 | SanDisk Sansa Fuze MP3 Player
How do you delete the photos from your sansa fuze
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 31, 2010 | SanDisk Sansa Fuze MP3 Player
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa fuze 8 GB comes with some songs already on it. I tried to listen to them and I do not like them. How can I delete them?
on the player, select the song, press the down button and scroll down until you find delete and delete.
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze deleted itself
slide the power switch to hold and then connect to system,....it must be detected as a removable disk....then format the player....that should fix the issue...if it doesn't you will need to reinstall the firmware....install sansa updater from the disk provided alongwith and use it to repir your player by updating its firmware...
Aug 22, 2009 | SanDisk Sansa Fuze MP3 Player
How do I delete multiple songs from my sansa fuse mp3 player?
HI,
To delete multiple songs you need to connect your Sansa Fuze to your computer and delete the files from the Music folder.Just press hold CTRL and select the song files with your mouse which you want to delete and then press the DEL button.
If you need any more help let me know.
Thank you
Aug 13, 2009 | SanDisk Sansa e260 MP3 Player
My sansa fuze 2gb screen keeps saying not enough space and then turns off.
try plugging it into the computer back up all the music and delete some of the songs then try tuning it on again
Mar 20, 2009 | SanDisk Sansa Fuze MP3 Player
My mp3 player won't turn off!
Slide the power switch up for at least 10 seconds, this will reset the Fuze. After which you should be able to power on your Fuze normally.
Mar 18, 2009 | SanDisk Sansa Fuze MP3 Player
Frozen
Reset your Fuze by holding the power slider switch in the "On" position for 15-30 seconds. Release the button once the unit begins to power down.
Jul 02, 2008 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
85 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
