Question about Microsoft Windows XP Professional for PC
I need program source code for vertical redundancy check,longitudinal redundancy check,isochronous communication
  • 1 more comment
  • AJAY YADAV
    AJAY YADAV May 11, 2010
    give me more info
  • Maurice B Thomas
    Maurice B Thomas May 11, 2010
    My sentiments, exactly, ****!
  • Dick
    Dick May 11, 2010
    Pay a computer programmer then. We don't do your homework for you here.
#include<iostream.h>
#include<conio.h>
void main()
char bin[10],c;
clrscr();
cout<<"\n\n\n\nEnter 8 bit binary no.:";
cin>>bin;
cout<<endl;
for(int i=0;i<9;i++)
if(bin[i]=='1')
c++;
i++;
if(c%2==0)
bin[8]='0';
cout<<"Even";
else
bin[8]='1';
cout<<"Odd";
cout<<bin;
bin[9]='\0';
getch();
Posted on Nov 22, 2009
Sir, i want the source code for vertical redundancy check problem on C/C++ languages
Posted on Aug 04, 2009
  • mrinmoy86007 Dec 12, 2010
    #include
    void main()
    int bitstream[8], i, j, count =0;
    printf("Enter 7 bit bitstream : \n");
    for(i=1;1<8;i )
    scanf("%d",
    Brigadier General:
  • 10,406 Answers
Did you try using any search-engine (BING, GOOGLE, ALTA VISTA) to help you do your homework?
Posted on Jun 08, 2009
I had the same problem too.. but i dont find your solution working either
Posted on Jan 02, 2010
Error code 0x800704B3 how to fix?
You have not mentioned what Operating System you are using so I assume it is Windows 7.
You will face this error if your RAM is very low. The main source of performance decreases are startup clutter, registry errors, RAM decline, fragmented files, unnecessary or redundant program installations.
In order to fix your errors and PC speed, it is recommended that your download the 'Error Code 0X800704b3 In Windows Repair Tool' from the link below. Ultimately you may also add more RAM and increase your storage space.
How To Fix Error Code 0X800704b3 In Windows Errors Windows XP Vista...
Nov 11, 2014 | Computers & Internet
"I have 1998 Volvo V70 AWD and my check engine light is on. I changed gas cap that one I got from the Volvo. Also I done smoke test few days ago, the mechanic couldn't find any leak. Now it show the code...
1--Evap system hoses
2--Purge Valve
3--Check Valve
4--Air pump
5--Canister valve(some people call canister purge valve)
A crack in an evap hose is the most common thing. I would definitely check the two evap canister hoses. These are easy to fine, one being the J hose, which is in a J shape, and connected to your canister and the other end to a valve. Then the Canister Evap hose, which is 18" or so long with a 4" L on the end of it. It connects to a hard plastic or metal hose that can easily be reached by removing the rear passenger side tire on a 98 S70 turbo. Check these 2 first. I found that the cracks in both of these hoses were where the clicks were or close to them(many old style clips causing this). Check these too, again they will both be connected to the canister valve that is right beside the charcoal canister on the passenger rear side.
Jun 13, 2014 | 1998 Volvo V70
We receive 43 redundancy failed hardware failure and second controller seem to be in idle stat please suggest what is actual problem
Here is explanation from HP manual how to fix that problem:
43 Redundancy Failed Hardware Failure
Type: Error
Description: While either attempting to enter redundant mode or already
operating in redundant mode, one of the controllers encountered a hardware
failure on the communication channel between the two controllers. Redundancy
is disabled at this time.
Action:
If the storage system is currently involved in host I/O:
1. Remove the standby controller.
2. Wait 10 seconds.
3. Reinstall the controller, and be sure that it seats fully in the chassis.
If this action does not solve the problem, wait until downtime is available and do
the following:
1. Power down the storage system (on page 28).
2. Remove both controllers.
3. Reinstall both controllers, and be sure that they seat fully in the chassis.
If this action does not solve the problem, contact HP support.
Sep 11, 2013 | HP MSA 500 G2 High Availability Kit...
Webcam not working on L300
The L300 does not support Isochronous devices (http://en.wikipedia.org/wiki/Isochronous). Thus USB based webcams, audio headsets, and microphones are not going to work.
Aug 13, 2011 | NComputing L230 Network Terminal
When i install,bluetooth setup in my desktop that time a information came like cyclic redundancy check problem.
Cyclic Redundancy Error comes when the source device like a computer calculates data and add the size of the information and sends it to the destination device. The destination device sees the size of the information and recalculate the size of the information and compare the two if they do not match the cyclic redundancy problem is reported because the information data has gone corrupt during the transit from the source to destination device. It can be a wrong configuration or packet collision. If it is due to packet collision the error can be over come by resending data multiple times.
Sep 11, 2010 | Computers & Internet
C language coding for vertical redundancy check method
Is this for an assignment?
It might do you better if you figure it out yourself :)
Once you have a go post your solution here.
Someone might help you with it.
Check out codeproject.com.
That place is full of examples and helpfull people.
Sep 04, 2009 | Microsoft Windows XP Professional for PC
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site www.kidwaresoftware.com/ and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  www.kidwaresoftware.com/.  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.    esakkisivaganesh@yahoo.co.in
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
Longitudinal lines
the lcd needs to be replaced take the phone to a mobile service center and have it done.
Oct 10, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Microsoft Windows XP Professional for PC Logo
1,495 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
