Question about Microsoft Xbox 360 Console
Error 71 on screen
Got a red light followed by error 71 on screen
  • vagaagaa Mar 22, 2009
    nothing works is my only other solution to turn in my xbox and have them repair it or is that even worth it how much does that cost because its almost probly cheap enough to buy a new one if i have to send the damn th9ing in why must these things happen i dont understand i want to shoot peope they wont let me and thats not fair **** that damn red light in the corner of my for lights its not cool its not cool at all that not coool so any way help
    Problem Solver:
  • 16 Answers
This error is caused by a bad update. go to the system blade, select memory, press y on the HD symbol, press x,x,Left bumper, right bumper, x, x, a message will appear, select yes
Posted on Mar 03, 2009
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
2008 mini Cooper code CC-ID 071
71
Dynamic Stability
Control (DSC)
Brake pads!
Replace
Brake pads
The brake pads are worn.
Have them replaced by the nearest BMW Service.
Feb 24, 2012 | Mini Cooper Cars & Trucks
Hi, i have problem E 74 one red light ..... would
E74 is due to an inherent engineering flaw and will continue on new consoles until Microsoft institutes a revision.
E 74, E 79, E 71 is shown on screen and a solution to fix it is by ensuring that your A/V connections on your Xbox 360 is secured. Another possible cause to the error is that there is a power surge or outage on your system.
BETTER U Click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 Elite Console
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Feb 08, 2010 | 1994 Toyota 4Runner
A red light keeps flashing and the screen says error when it comes on
If you have a red light flashing then you have one of the following: 1 red light e74, 2 red lights - overheating, 3 red lights GPU and the CPU, or 4 red lights you need to plug the av cable in.
For the 1, 2 , 3 red lights you can send it in to get it fixed or reapair it yourself with a good guide
Oct 26, 2009 | Microsoft Xbox 360 Console
When i turn on my xbox one red light come on an it say system error contact xbox customer support systemfehler E 74
One red light means one of the following, according to Microsoft:
This type of error will show an Error On The Screen. The Error List Is As Follows:E64 - Error: Key Not Valid Or Firmware Problem.
E65 - Error: Key Not Valid Or Firmware Problem Or Flashrom Is Not Responding.
E67 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E68 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E69 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E74 - Error: Video Cable Problem. Possible Damaged Video Cable
Depending on what error code you get, try fixing whatever the corresponding error message is, above.
Mar 19, 2009 | Microsoft Video Game Consoles & Games
When i start the xbox it runs but nothing comes out at screen
I have fixed on with the same problem. Everything works but now video on the screen. You will need the same fix as the 3 red light.
Check out this site for a repair kit. It's like $10 and you get everything you need.
Xbox repair kit
Dec 18, 2008 | Microsoft Xbox 360 Console
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Xbox 260 error 71
put it in a towel and shake it n a circle IT WRKS
Apr 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
157 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
