Deer sir my intel 845 pentium iii intel board is not display manly wich is Cause ? please solve me
  • 530 Answers
Hi im josh in cebu phils.may i help you?The most common caus of no display is the malfunctioning of your video card. Try to check first the connections if not loose.then next try to check the video card if not seated properly in the video slot.Tighten firmly the position of the video card.Verify the correct jumper settings for video cards that are mounted to the motherboard. it will require you to check the documentation that shipped with the hardware good luck !
Posted on Feb 21, 2009
Hi sir/mam, i have a gigabyte motherboard 7vm333m-rz n now i m presently in tis board AMD processor is running... can i change the processor by pentium 3 instead of AMD.
-> NO
It has a Socket 462 processor socket. (Also known as Socket A,
http://en.wikipedia.org/wiki/Socket_A )
This is strictly for AMD processors ONLY, and only for AMD processors that use this processor socket.
An Intel Pentium III processor, that is not a Slot 1 processor, uses a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
List of Intel Pentium III Microprocessors,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down also.
{ If it states Slot 1 AND Socket 370, it means there are processors Intel made, that were that model, but could have been a Slot 1 processor, or Socket 370 processor.
Using the first example;
Pentium III 500E,
http://www.cpu-world.com/CPUs/Pentium-III/index.html
The first example on top, is an Intel Slot 1 processor style.
The rest of them on down are Socket 370 processors, EXCEPT for the Pentium III Xeon. (Zee-On)
It is a Slot 1 processor.
http://en.wikipedia.org/wiki/Slot_1
Want to learn more about computer technology? Post back in a Comment, and I will give you some links.
Regards,
joecoolvette
Jul 21, 2012 | Computers & Internet
Dear sir intel 845 , MS-6714 ver:1 per processor intel pentium 4,2.40ghz/1m/533,SL86Fcosta rica support or not thanks Narendra
Your board is MSI, you can accsess their website here;
http://us.msi.com/index.php
You can get downloads and have them scan your system with their "live eye". It has Intel 845GV and ICH4 chipsets and Realtek ALC650 with AC97 codec for sound, It also has Realtek LAN. It can use Intel Pentium 4 or Celeron processors, up to 400-500 MHz. This is Intel's site:
http://downloadcenter.intel.com/
I will also give you Realtek's site:
http://www.realtek.com.tw/
I'm not sure what you are looking for but, I hope this helps you.
May 23, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have pentium 4 processor & 845 GZD chipset from last one month my LCD 19 is not displaying with this board but 15 TFT monitor is OK with that so can i know how to solve this
most likely the monitor receives a signal/resolution it can't accept. Try to boot in the BIOS - if it's the same then the monitor itself is defective and you must take it to be repaired.
Oct 01, 2010 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Drivers for intel 845 gvsr with p4 2.4 gHz for windows 7
please visit the website below and search for your board 845 then select your operating system in the right hand box and the drivers that are available will be show below hope this has helped http://downloadcenter.intel.com/Default.aspx
May 22, 2010 | Intel D845GVSR Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Mother board Intel p-4 can be converted into D.865 it is possible
D-845 is not updatability to become D-865 that was already design on that model of motherboard.
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 24, 2007 | Intel Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ihad computer pentium 4 mother board asus 845 processor 1.7 my problem that computer open windows normally then making restart again can u solve it
1.) You are infected
2.)One of ur drive wont work propertly
3.)Problem with ur Power Suply
4) Problem with RAM MEMORIE
And use ur WINDOWS XP CD to repair windows
Oct 10, 2007 | Intel Motherboard
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
