Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Pioneer Media Receiver PDP-R06Uthe power light flashed 8 times then pauses and repeats the tv powers on for appox. 5 sec then turns off.
  • drsl62 Apr 22, 2009
    Pioneer Media Receiver PDP-R06Uthe power light (blue)flashed 12 times then pauses and repeats the tv powers on for appox. 5 sec then turns off.
2 Suggested Answers
thedayos
  • 57 Answers
SOURCE: Pioneer PDP-R06U media receiver
On this model, this is a "fault code". The unit has attempted to power up and the processor has determined a fault with it's "self check" diagnostic test it runs each time the unit is turned on. A technician will have to test the unit to determine the nature of the fault.
Posted on Feb 27, 2009
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pioneer media receiver pdp r06u
no if it didn't have a tuner it would not even have a picture he is lying
Jan 28, 2014 | Pioneer Plasma Media Receiver Pdp-r03u
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
PIONEER PDP-R06U / PRO-R06U MEDIA RECEIVER SERVICE
Hey,
This may be too late...
I got it from the field manual.
Trap Switch Reset Procedure
G-4, G-5, G-6, G-7, G-8
• Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
If the model in question has the TV Guide option, the TV Guide
option must be turned off before proceeding.
• Using the customer’s remote control enter “service mode” by pressing the
following key sequence:
1. Press the “display” button then release the “display” button.
2. Wait between 3 and 7 seconds
3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
• Panel will now turn on in “service mode”.
4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
Until the display shows the “initialize” page.
5. Press and hold the “display” button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the “power” button on the remote.
I had to try it a couple of times before I got it to work. I.m not too sure how to turn off the tv guide mode. I just held it in for a couple of sec,s.
Good luck
Dec 05, 2009 | Pioneer Audio Players & Recorders
Media Receiver Shut-down, Blue LED Flashing for Pioneer PDP-R06G
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 10, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Feb 27, 2009 | Televison & Video
Pioneer pdp 503
Hi, my PDP 50XE just cut out, when powered back on the screen powers down and the standby light flashes twice followed by a 5 sec gap.  Anyone got any thoughts? Thanks
Jun 28, 2008 | Pioneer PureVision PDP-5030HD 50 in....
PDP-436PG
maybe its not worth the effort. the media or turner box must corsponed with the model of the pioneer tv, in order to work.
Apr 09, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
BLUE POWER LIGHT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Jan 26, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
816 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
