Question about HP Office Equipment & Supplies
Printer installation unable to add printer attached to another pc (all in same network)
  • 1 more comment
  • ananth_012 Feb 21, 2009
    the printer is hp officejet 5510.os ic windows xp. 10 pcs attached in network.printer in one of the pc's. need to share the printer in another pc.help pls...
  • Grognard
    Grognard May 11, 2010
    What operating system are you using? How are the computers connected? Can you access each computer from the other?
  • Richard Liao
    Richard Liao May 11, 2010
    You use network printer ? What is your Printer Model number ?
  • 67 Answers
Best way to hook up a network printer is to connect the printer to the same hub that the other computers connected to. Go in to the printer menu on the printer and print the configuration. There is an IP Address on the configuration page. After that on any computer hooked up to this network, go to start, printers and faxes, add a printer select local printer, slect add a new port, and type the IP address of the printer and click okay. If the drivers are not recognized you may need to install them by the CD came with the printer or download it from internet. Good luck :)
Posted on Feb 21, 2009
    Scholar:
  • 60 Answers
On the computer that the printer is connected to, go into the Printers and Faxes window, RIGHT click on the printer you want to share and select "Sharing...". After you finish going through the printer sharing wizard, go to a different PC and try to add a printer, select network printer. Make sure that the computer that is sharing the printer is on during this process, it sounds strange to have to mention this I know but you would be surprised. I'll check back later to see how things worked out.
Epson l100
SETTING UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer -
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click
Share this printer, and then if you wish you could change the Share name, then click OK
3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached
to another computer - Next.
2. Select Browser for a printer - Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next
4. Select Yes for - Use this printer as the default printer - Next - Finish
5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
May 07, 2013 | Computers & Internet
Tip
Setting up a Shared Network Printer
Follow these steps to set-up a shared network printer :-
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, then if you wish you can change the Share name, then click OK
3. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
1. Open Printers and Faxes – click Add a printer – Next – select A network printer, or a printer attached to another computer - Next.
2. Select Browser for a printer – Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer – Next
4. Select Yes for - Use this printer as the default printer – Next – Finish
5. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
on Dec 19, 2009 | Office Equipment & Supplies
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
How to make mp760 wifi
This printer has only an USB connection that connects to your computer and cannot connect to wireless network directly. You can attach this printer to a wireless printer server/router to enable wireless printing.
OR
SET UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer. You need to install the printer driver on the computer and configure it as a Shared printer. The other computers on the network need to add this printer to their computer. Follow these steps to set-up a shared network printer :- 1. Connect the printer to the computer and install the printer driver. 2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change the Share name, then click OK 3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation. Follow these steps to configure the computers on your network :- 1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for a printer - Next 3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Use this printer as the default printer - Next - Finish 5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Dec 02, 2012 | Office Equipment & Supplies
Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 27, 2012 | Konica Minolta Office Equipment & Supplies
Can't find printer on network
1.How are you attaching to the network printer from your daughters computer? IP address, or by the name of the printer...Also make sure you check you are attaching to the network printer, and not local printer.
2. Install the Microsoft TCP/IP version 6 protocol on both computers by clicking install on your LAN properties, then restart PC. This should work!
May 13, 2009 | Microsoft Windows XP Home Edition for PC
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
My HP Officejet 6310 All-In-One InkJet Printer is unable to complete the network installation
Are you connecting via usb or ethernet cable?
Through usb you need to install the driver on the pc it is connected to. Then share it.
Through ethernet make sure your CAT5/Ethernet cable is connected from your printer to your router/switch. Through the menu on the printer Print the network setup.
Then from your web browser type
http://ip address of printer from the network setup page
If you can then you need to add the printer driver on your pc and use a tcp/ip port to print to it through the network.
Sep 04, 2008 | HP Computers & Internet
Network printer problem
Please let me know whether the printer is connected drirectly to a swtich with a print server or through any client pc in the network.
if its a print server you to get the IP address for the printer and add printer->choose local printer attached to this computer uncheck automatically then create a port ->type of the port standard TCP/IP give the ip address and then follow the step and its driver files etc.....
if its connected to the pc check the pc ip address ping it and know the pc is alive on the network and the printer is shared over the network then go to add printer you will choose network printer and browse for the pc under the pc u will find the printer
click over it and do the rest ...
Easy way go to the My Network places ->View workgroup computers -> choose the computer with printer double click then you will see that printer right click on the printer and choose connect - problem solved
Thanks
Hothawk
Jun 26, 2008 | HP Pavilion dv6000z Notebook
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
113 people viewed this question
Seeker5211
Seeker5211
