Question about Sony Playstation 3 (PS3) Console
Turn power on with a steady green light but nothing appears
Nothing appears on the tv. No menu or anything. I tried switching channels from video 1 to video 2. A disc loads fine but nothing.
  • 2 more comments
  • Anonymous Feb 21, 2009
    exactly the same thing ill have best buy make it better
  • thewagon Feb 22, 2009
    System seems to power on. The lights come on, but there is no sound or menu or anything. The discs will load fine, but nothing at all happens.
  • Anonymous Feb 22, 2009
    I have the same problem. The discs will load and eject, (with no video) then when I try to power it down because it is unresponsive the power button on the console will not respond.
  • dooot Feb 23, 2009
    I turn my ps3 on, I can stick in a game, but nothing shows on my tv.
    When I listen to the ps3 as I turn it on, it gives a slight "whiiirrr" and then that's it.
  • 3 Answers
Try it on another TV if nothing shows up then your PS3 or the video plug is broken.
Posted on Feb 21, 2009
My vizio tv turns on but had no display
UNPOWERED INPUT DEVICE
Check to make sure the device you're trying to use with your TV is plugged in and turned on. While it may seem like a silly oversight, it is possible that you switched on your TV and didn't actually turn on your DVD player, gaming console or whatever device you're trying to enjoy. If you tried to use a remote to turn on the device, check that the batteries still have a charge and turn on the device using its built-in power button.
TIP The problem may be your input device itself. Check your TV with other devices and see if it displays them properly. If it does, contact customer support for your device for more detailed troubleshooting instructions
WRONG INPUT CHANNEL
Make sure that your TV is on the right input channel for the device you're trying to use. When your TV isn't switched to the right channel, no visual or audio input from the device will display on your screen or through your speakers. Turn on the input device and press the Input button on your remote to cycle through your input channels until you see the device's display on your screen.
AV CONNECTION PROBLEMS
If you're on the right input channel and your device is turned on, there may be a problem with the physical connection between the device and your TV. Make sure that all cable connections are secure, and also that all cables are connected to the In ports on your TV and the Out ports on your input device. If you're using a connection that has color-coded plugs, make sure the connectors are inserted into their appropriate color-coded ports.
If you're using an HDMI connection, make sure that the cable you're using is compliant with High-bandwidth Digital Content Protection, especially if your TV and input device are both HDCP-enabled. HDCP is a copy protection system that prevents the copying of digital video and audio content as it travels over the connection. Systems connected with non-compliant cables won't display any video or audio conten
FROZEN TV
Periodically a TV may freeze up, showing that it's still turned on but not actually displaying any information from your input device or the TV's menu system. To fix a freeze, power cycling is the best solution. TEP 1 Turn off the TV by pressing and holding the Power button on the cabinet until the TV powers down.
STEP 2 Unplug the TV from the wall power outlet.
STEP 3 Press and hold the Power button on the cabinet for 30 seconds, and then release it.
STEP 4 Plug the TV back in and turn it back on using the Power button on the cabinet or your remote control.
HARDWARE OR SOFTWARE FAULT
If everything is correctly set up, powered on and on the right channel and you still aren't getting any picture or sound, there may be a hardware or software fault in your TV. The best way to check is to press the menu button on your TV or remote and see if the on-screen menu appears. If the menu doesn't appear, contact repair
Sep 28, 2016 | Vizio SV Televison & Video
When I try to hook my Sega Genesis up to my TV, why does nothing happen?
you should have a red light and if its on it should be working. I would just go on Amazon and buy a AV connector for the system, no need to use RF like its 1989 :)
Dec 31, 2015 | Sega Genesis Console
No sky no happy
Unplug from the main power and that should reset your sky box. If still no signal get the dish looked at by a tv aerial company.
Apr 07, 2017 | Philips Televison & Video
Have power but nothing else
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
kibirag19
Dec 27, 2009 | Nintendo Wii Console
Poor picture quality
Hello Paul. I have this same monitor, but rebranded, Access the service menu with the remote control:
With user’s RC
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Sound-> Balance
4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
6. Press the standby button then AC turn off and restart the TV, which can exit factory
OSD menu.
Now you will be able to change the values for Red Green and Blue channels. I also hated this TV, but after adjusting the colors it's looking great! Hope you could fix it too! :)
Nov 16, 2009 | Televison & Video
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Sony KV-32fs16 picture blinks + no input from remote + stuck in video 1 + no sound
the EEPROM chip has to be replaced and the coversion IC need to be replaced
as for the sound this may be a transistor pre amp or the volume IC
Oct 20, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Sanyo vizon dp42746 problem
Anyone have a suggestion for this? This thing is a year old and is kaput.... anything????
Oct 01, 2007 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
116 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
