Question about Icom IC-R5 Handheld Scanner
If you where going to Buy one radio which one would you Buy?
Which radio would you Buy? Icom IC-R2 or the Icom IC-R5 or the Yaesu VR-500 ? Thanks for your Time......................
    Problem Solver:
  • 8 Answers
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Posted on May 02, 2009
I have a icom ic-r5 scanner that will not start
Check the battery contacts. Sometimes there may be corrosion on them from old batteries. You can also check the contacts that connect the logic board to the battery contacts. There are two small Philips screws in the battery compartment. Remove them and the back cover comes off. You can check the contacts on the inside of the back cover and see where they make contact with the logic board. Make sure all contacts are free of corrosion. If it still will not power up. try a CPU reset. While holding down [FUNC] and [V/M], turn the power ON to reset the CPU.
Nov 02, 2010 | Icom IC-R5 Handheld Scanner
I have been using the IC-R5 for a few years now with no problems except when using it during the summer. If the weather is hot, after being switched on for a period of time the scanner just starts to bleap...
The occilator that "locks" the VFO (like a clock signal) is gong out of range. The higher temps are affecting the temprature controlled occilator. I would send the unit to ICOM for repair.
Jun 21, 2010 | Icom IC-R5 Handheld Scanner
Icom f-10 vhf,wish to programme,have speaker jack plug and software,how do you get the radio into programming modr??????????
Go to ICOM's web site and down load the free software. Otherwise, download the manual there in PDF format. You can go to for more information.
Jan 28, 2010 | Icom IC-R5 Handheld Scanner
Ic-r5 scanner will not connect to my xp computer
If you have re-loaded the software and then connected the scanner the pc should say "found new hardware" if this is not the case then the port may be inactive, try loading the software using windows add new progs in control panel and see if this solves the problem. You can check the ports by going into control panel / system / device manager / ports. By the way, are you using the ICOM OPC 478 lead with the inbuilt electronic converter in it!
Jun 17, 2009 | Icom IC-R5 Handheld Scanner
Programming issues with Icom F21
What you have is a programming issue. The radios need to be "cloned" so they will all work together. You can buy the software on line for about $65.00 then you can change frequencies when ever you want.
Nov 17, 2008 | Icom IC-R5 Handheld Scanner
Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Sep 06, 2008 | Icom IC-R5 Handheld Scanner
The only thing you can do about this problem is to buy a Uniden product.However the problem about this is that it does not get all frequencies unlike this model.
Dec 01, 2007 | Icom IC-R5 Handheld Scanner
Radio shack pro-97 hand held scanner
you can go to scanner and get what frequencys you need. if this don't work let me know i will give you a new site.
Oct 31, 2007 | Icom IC-R5 Handheld Scanner
Icom IC-R5 Handheld Scanner Logo
393 people viewed this question
Top Icom Radio Communications Experts
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
