Sharp Wizard OZ-730
Problem for Sharp Wizard OZ-730
I am having difficulty importing an address database to Outlook
By Green1 - usenet poster
I have a SHARP WIZARD OZ 730, and I want to import its address database to
Outlook Contacts. The SHARP uses Daytimer Software. The export process seems
to work fine, but when I go to the step to import to Contacts, I get an error
message that says the Separated Values (DOS) translator is unable to
recognize the file (the exported Daytimer address database) that I am trying
to import. I am using Outlook 2002. Does anyone know anything about whether
there is a different translator in 2003 than there is in 2002 or about why I
am having difficulty importing from the Daytimer Software through the Comma
Separted Values (DOS) translator in Outlook 2002?
Same Problem
Jan 05, 2008
-   I am trying to export my data from the DaytimerSharp wizzard 0z-730 to Microsoft outlook 2007. I am getting the error message that I do not have the rights to execute command? I have reinstalled the software on my new computer and restored the data and the day timer works great. Now I need to move the data to Outlook 2007. Any ideas?-   Guest
Best Solution
posted on Aug 01, 2007
Very Helpful)
Rogers
Rank: Apprentice
Rating: 0%, 0 votes
I'm having the same problem and dont have the disks. My software was already
loaded when I bought the PC and my kids ruined the disks (long story).
Anyway I can download the files or is there any other way to export contacts
to csv without the files?
Was this helpful?
Yes
No
Solution #2
Helpful)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
Thanks, Karl. I really do appreciate your confidence in my sanity. I*'ve
been fooling with this problem for so long, I could probably have manually
transferred the data a few times over, but now I'll hit Sharp one more time
tomorrow. They can't seem to see my point that the file seems empty. Eileen
Was this helpful?
Yes
No
Solution #3
posted on Oct 22, 2008
Not Rated)
bcribb
Rank: Apprentice
Rating: 0%, 0 votes
I am having a similar problem. I have managed to export my tungston contacts list into an excel file and save it as a csv file. However, outlook refuses to recognise the csv file. How can outlook be persuaded to do so?
Was this helpful?
Yes
No
Solution #4
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
If I understand what you're saying, then the file that DayTimer is creating
is being created as a zero-length file. If that's the case - then the issue
absolutely belongs to Sharp/Daytimer and has nothing to do with Outlook.
You're right - there is no data there to import so doesn't much matter what
version of Outlook your using (and we haven't seen differences in the CSV
translators for O'2K thru O'2K3 - leastwise not for anything we've tried to
date).
Karl
Karl Timmermans - The Claxton Group
ContactGenie - Importer 1.3 / DataPorter 2.0
"Power contact importers for MS Outlook '2000/2003"
Was this helpful?
Yes
No
Solution #5
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
Hi, Karl:
Thanks for your helpful suggestions. I will try all to see what happens. One
thing I seem to notice is that the exporting from the Daytimer software seems
to work well, but when I go check the file I have exported as a csv, it is on
my hard drive as a file but seems not to have the data in it. In fact, it
comes up as a "0". I've talked with Sharp about this, but they can only
suggest that perhaps the translator in 2002 is not the same as in 2003 on
which the transfer process was tested. I think the Daytimer is not fully
exporting the data to the created file. Then, the translator could be giving
the error message because it just isn't finding data to translate. Eileen
Was this helpful?
Yes
No
Solution #6
Not Rated)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried using CSV Windows translator? If that doesn't work
Since not all CSV files are created equally - one quick thing to try is
opening the CSV file in MS Excel and if it works - just save it again. Use
that file to import (CSV Windows) into Outlook.
Failing the above - another thing to check is what "text qualifier" (the
character that starts/ends each field, i.e. double quote, single quote) is
used in the CSV file and if you have MS Access - import the file using the
correct "text qualifier". When done just simply import the Access file (or
export it again as a CSV file). Hopefully the above will work and you won't
have to go thru all this aggravation.
Karl
Was this helpful?
Yes
No
Popular Solutions for Sharp Wizard OZ-730
Questions and Unsolved Problems for Sharp Wizard OZ-730
Do you recommend Sharp Wizard OZ-730?
Answer
Answer
Have Sharp OZ-730 whose "2nd" and "Caps" keys stick. Makes it difficult to key... (More)
Answer
I have an old Sharp Wizard OZ-290H with PC Sync. I don't ever remember any kind of cable with it... (More)
Answer
I can't back up my Sharp Wizard OZ-650 to my computer. I am using Rupplynx version 1.2. It starts to... (More)
Answer
some of the stored information hard to read,white lines run up and thru the stored info is there... (More)
Answer
Transfer address file to a apple computer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp Wizard OZ-730:
Top PDA Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
