Question about Rockford Fosgate Car Audio & Video
I cant find the wiring harness i need
Im looking for a wiring harness for my Rockford Fosgate model #FF9120 car radio, it has to be a 16 pin harness. enyone that knows enything about it let me know thanks.
  • 156 Answers
SOURCE: rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Posted on Aug 16, 2007
  • 626 Answers
SOURCE: Searching for wiring harness sequence.
Found a service manual here, but you have to pay for it (only 4.95 USD). It has the wiring block specs you are looking for.
Best of Luck.
Posted on Nov 04, 2007
  • 17 Answers
SOURCE: where is the aux plug for this radio
The Mitsubishi Eclipse with the Rockford Fosgate premium audio system does not actually have an aux plug. When you are scrolling through the sources, one of them listed is an AUX. This implies that there is a headphone jack somewhere in the vehicle where you can plug an iPod into and play it through the system. The port, however, was never actually installed on all pre-2009 eclipses.
The only way to access this feature of the stereo is to obtain an AUX cable from the mitsubishi dealer, which will be a wire harness that connects to the back of the head unit and provides an additional AUX port cable allowing you to plug in your iPod. You can talk to your local mitsubishi dealer about the cable, from what I hear, its rather expensive, and then go to best buy, somewhere similar, to have them install it.
Posted on Aug 06, 2009
  • 1305 Answers
SOURCE: I have a 2001 Dodge Ram 1500 that I'm trying to up
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Posted on Sep 09, 2009
  • 547 Answers
SOURCE: Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
Posted on Oct 02, 2009
Were the wiring harness plugs in on the back of my rockford fosgate rfx 9220 What each one of the pins are excatly. I am having a hard time reading the diegram
Are you talking about the diagram on the unit itself? Are you trying to install without the factory harness or are you just wondering what wire are what?
Nov 23, 2016 | Rockford Fosgate Car Audio & Video
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
Im looking for the wiring diagram for the rockford fosgate 4000.1bd
Did you try contacting Rockford Fosgate? They have a website
Apr 28, 2011 | Rockford Fosgate 40001BD Car Amp
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
I would like to ask what are the things needed to replace my single in dash stereo with a 6 cd changer rockford fosgate stereo? My car is 2008 mitsubishi eclipse gs.
what you will need is
1 new radio
2 dash kit
3 wire harness
4 antenna adapter
5 maybe a radio interface to adapt the new radio
online store comming soon
can ship you any thing you need take visa master card
Oct 14, 2010 | Mitsubishi Car Audio & Video
How do you do the video bypass for a fosgate lancer navigation?
You need to pull out your stereo. Find the parking brake wire on the back, leave plenty of room and cut it. Now wire it right back to the radios ground wire in the harness. This will tell the radio that you are always in park.
May 14, 2010 | Rockford Fosgate RAVDVD2 Car DVD Player
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
Rockford fosgate installation?
The best way to install a stereo deck is go get yourself a Scoshe wiring harness. This will allow you to wire the harness directly to the stereo, then plug directly in to the OEM wiring clip that is plugged into the factory stereo. It helps if and when you sell the truck and want to put the factory stereo back in. Plus you dont have to hack up wires. Hope it helps. You can get the wiring harness from any car stereo installation or customization shop.
Jul 27, 2009 | Rockford Fosgate RFX-9000 CD Player
Missing Wiring Harness
Best Buy Road Shop. They use to sell Rockford, don't know if they still do. Hope this helps
Jul 09, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
