Question about Cooktops
Gas oven knobs seizing when oven hot
The knobs that control the hotplate on a freestanding gas oven and cooktop stick and can not be turned when the oven below is in use. Obviously the extra heat from the oven is enough to cause them to seize, difficult when the hotplate is in use and the oven, have to wait for the oven to cool off before I can turn off the hotplate control knobs. The oven door seal is fine. It is not excessive heat that is hitting the control knobs they are not hot at all. Is it possible to disassemble the control valves and lubricate them??
  • 63 Answers
Hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Posted on Mar 11, 2009
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
I am experiencing some problem with the controls on the cooktop. When turning the dial to the desired temp, sometimes the burner comes on, sometimes it does not. Some of the burners only engage when we...
I haven't heard of this problem before. If you do press down and the hotplate starts to work we know that the hotplates are okay. The only thing this could be is an internal problem inside the hotplate controller, possibly with the contacts. The controllers will need replacing.
Mar 04, 2011 | Whirlpool GJC3034 Electric Cooktop
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
Aug 19, 2009 | GE Cooktops
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
Cooktops Logo
310 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
