Question about Saeco Royal Professional Espresso Machine
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
I just bought a Saeco Royal Professional today, and the cappuccinatore works beautifully except for the fact that the milk comes out luke warm... about 125 deg F. Is there any way to get the milk warmer? I am starting out with milk right out of the fridge... should I warm the milk first??? This defeats my purpose, so I'm hoping that I'm just missing something. Thanks in advance!
    Scholar:
  • 75 Answers
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Posted on Feb 22, 2009
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
Where J can buy cappuccinatore
You can usually buy the kits from most online dealers but if you just need the cappuccinatore I have some for $5 plus shipping. saecosmart@yahoo.com
Feb 07, 2011 | Saeco Royal Professional Espresso Machine
No Cappuccinatore or Steam and Loud Bang!
The steam is ariving to the steam wand with a thin teflon pipe which is conected to a easy clip on union. So probably by the presure of the steam in the pipe since the capucinatote was gogled the pipe have been came out from the union so the steam is leaking in the machine. Be carefull not work the steam since the water in the machine can make an electrical short and damage the machine completly. Now in order to fix the problem first you must remove the top and side panel in order to connect back the steam pipe to the wand union and second to clean the capucinatore by complitly desasemble it put it in special detergent and leave it fro some our so any dirt will be removed more easily and by a good visual inspection you can see that all holes are cleaned from any dry milk.
Jun 05, 2010 | Saeco Royal Professional Espresso Machine
How can I make the milk hotter using the cappuccinator?
Yes you can make a small trick for that. You can use a sqweeter on the milk silicone hose so the milk can flow with more dificalty as long as you can see milk flowing this can be up to 78 C . You should keep the cappuccinatore very clean since you will need the steam to come as easy as possible
Feb 04, 2010 | Saeco Royal Professional Espresso Machine
I HAVE A GRIMAC MACHINE CAN I PUT A CAPPUCCINATORE?
Their is a cappuccinatore for every machine that have a steam wand
Dec 04, 2009 | Saeco Royal Professional Espresso Machine
Cappuccinatore does not draw milk
Hi
There should be a little knob on top of the cappuccinatore. It is what causes the milk to flow up the tube. When it is steaming, rotate the knob slowly until the milk starts to flow up the tube. You can fine tune the knob to get the best foam.
If you are missing the pin that has the knob on it, there will be a small hole in the outside top of the cappuccinatore. If you don't have hole and a knob, it is broken off and you need to replace the cappuccinatore
Oct 19, 2009 | Saeco Royal Professional Espresso Machine
No Hot Water when you press the button
I uploaded a file on descaling your machine at this site groups.google.com/group/espresso_worlds moz-screenshot.jpg
Mar 20, 2009 | Saeco Royal Professional Espresso Machine
I am looking for a replacement cappuccinatore automatic milk pin
check out the enclosed link:
http://www.cafeparts.com/SearchProducts.asp
Let me know if this helps.
Have a great day!
Mar 06, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
425 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
