Question about Hitachi 43UWX10B 43" Rear Projection Television
TV won't turn on. Red power button flashes then shuts off.
Had a convergence problem, and replace the IC's (STK 392-110). Now the TV won't turn on. The power button flashes 4-5 times and then shuts off.
  • 1 more comment
  • Anonymous Mar 08, 2009
    I just have a constant red blinking light with clicking sound. I trash picked this in excellent physical shape, but it will not turn on...any help would be great!
  • kasara Apr 01, 2009
    I have the exact same problem, replaced IC's and some resistors and now TV won't turn on, hear a clicking, power light flashes 6 times and then shuts down. I know the connects are correct b/c I had photo before I disconnected to soder.
    bnmdaniels - did you ever figure out how to fix?
    Thanks
  • www_kentucky Apr 10, 2009
    when pushing the power button, the TV clicks, the red light comes on, then the TV shuts back off 1-2 sec. later, with no blinking of the red light. Sounds like it wants to come on and show picture but cuts off right before. model# 50ex8k serial# val015318
  • Hitachi Master
  • 3,459 Answers
Check your soldering. If you shorted two pins together the TV will shut down. This is common. Just desolder the shorted section and resolder it again. This will typicaly fix it.
Posted on Apr 08, 2009
Did the TV work but with a convergence eproblem before you changed the STK's.? If so it is very likely you have misplaced one of the several leads when reassembling the set. It is ususally a perfect cure. Power light flashing 4 times indicates this type of problem.
Posted on Feb 21, 2009
Toshiba tp50g90 projection tv, red flashing light won't turn on
FYI: WHOEVER told you 110 chips can be replaced with 120 chips is wrong.
Easy way at this point to way at this point to see if chips are the problem is to UNSOLDER AND REMOVE BOTH CHIPS. Make sure not shorted connections and power set up---set will function without the chips but look terrible.
Try Suburban Electronics for the correct chips----only safe replacement for them is the 150 chip----stk-392-110 and stk-392-120 are not interchangeable.
The blinking light indicates a short.
LET ME KNOW IF YOU HAVE QUESTIONS AS I HAVE FIXED hundreds OF THESE SETS.
Jan 16, 2012 | JVC Televison & Video
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
Installed new lamp ..tv turns on then shuts off standby light flashes for a few seconds then tv turns on then shuts off again
did you replace the all three lamp the red,green and blue lamp?if not what color of lamp did you replace?try to dis connect the lamp that you installed then power the tv again if it work there might be a problem on your compatibility of lamp u use..or you can replace the convergeance ic there are two big ic in there sometimes labelled STK replace them...hope this could help..good luck!!
May 21, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Mitsubishi 55411 projection tv has red band across bottom
go into the customer menu and select convergence with the original remote; if either the red or blue will not move in some direction, you have a bad convergence IC(the WS-55411 uses two STK-392-110 CONVERGENCE IC chips)
Aug 12, 2009 | Televison & Video
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Rca d40w20 tv convergence and power on problems
The problem is most likely due to a defective convergence IC.
There are two convergence STK ICs located on the convergence board.
You need first to test the ICS, by checking for continuity the pico fuses at the base of the ICs, then replace the faulty STK.
You should trying doing it yourself only if you are a proven electronic repairer.
Nov 07, 2008 | RCA Scenium D40W20 40" Rear Projection...
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Thanks
Oct 11, 2008 | Televison & Video
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Dec 07, 2006 | Panasonic PT-53X54 53" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
418 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
