Question about Panasonic KX-TG1033S Cordless Phone
I have a 3 set of the above system KX-TG1033S. No dial tone
I only get a continual beep sound like a busy signal. On the screen it says new message. But I cannot get the answering machine to work. Our non pansonic phones work fine so it is not the telephone line and I have checked all of the pansonic phones to make sure they are on their bases and connected well.
  • 71 Answers
Try power cycle , or Reset base ,from handset menu . Check it out if there is reset menu in menu/setting /reset ...simular like that .
Posted on Feb 21, 2009
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
My panasonic kx-tga431al has all of a sudden changed the dial tone. instead of the regular tone, it now has a tone that sounds like a busy signal... what do i do to fix this?
Have you set up 'Call Divert' which returns a 'Broken Dial Tone'
Dial #21# if it is on a Single Line Telephone, or if fitted on a Business System check programme for 'Call Forward'
Jun 30, 2010 | Lands Phones
No dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Feb 15, 2010 | Panasonic KX-TG1033S Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Accidentally locked handset KX-TCD510
    try code 1000, that seems to be standard lock code pre-set for the phones, else take battery out for about 10 minutes or so ( this will likely erase your info, but you cannot get to it anyway). good luck!
    Feb 08, 2009 | Panasonic KX-TG1033S Cordless Phone
    Dial tone
    my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
    Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
    Panasonic KX-TG1033S Cordless Phone Logo
    217 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
