Question about Canon iR 2016i Black and White Copier
Canon iR2016J pls help me, my copier not functionning it shows Enter Dept ID and Dept ID Password Pls give solution
  • synvmail Apr 20, 2009
    please help fix my copier, when login its saying enter user ID and ID password
  • adel omer Apr 27, 2009
    hi i have problem with my canon , i want to yose it like a printer
    & i can't find drivers
    New Friend:
How to remove DEPT ID:
PASSWOR:
CANON IR 2318L
nikhilvtv@gmail.com
Posted on May 24, 2013
    Problem Solver:
  • 17 Answers
Dept. ID is activated that is why it is asking you to enter it. If you are not needing the function you can ask the local service provider to check the settings of your machine.
Posted on Feb 21, 2009
I FORGET THE DEPT ID AND PASSWORD OF CANON IR 2022 COPIES
you can clear all passwords in service mode.
Procedure:
1) Selecting Service Mode
Press the Additionalfunctions
key, 2key, 8key, Additional functions
key sequentially
now choose #CLEAR and ALL press OK
Now the copier is on factory settings and without password.
Note: you need to enter user data and IP settings, because everything is cleared.
Hope that helps!
Aug 23, 2011 | Canon Office Equipment & Supplies
Enter DEPT.ID & DEPT.ID Password how can i solve it can any give to reset setting codes
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
Jun 17, 2011 | Canon Office Equipment & Supplies
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
RESET PASSWORD FOR CANON IR2016 COPIER. I LOST THE PASSWORD.
My Canon C-IR2016 is demanding a Administrative ID & Password.
I did entered the Admin PWD and latter removed it. but can't really
tell what happen that after I restarted the copier, it still requested for
the Admin ID & Password. unfortunately the the details i used before
is not functioning any more. PLEASE I need Help !! thanks
Oct 06, 2010 | Canon iR 2016i Black and White Copier
I have canon ir2016j it has usb port, but when I connect it to the comp it doesn't show that the new hardware is connected, could yo help with it please?
i would download the drivers and install them before you say that there is a problem. come computers don't auto reciginise that there is a printer attached to them untill the drivers have been installed.
you can download the proper drvers from canon.com
Jun 26, 2010 | Canon ImageRunner 2016 Copier
I WANT CANON IR2016J PRINTER DRIVER
i need canon IR 2016 J Drivers for Window & platform.Can someone help me??
Jan 02, 2010 | Canon imageRUNNER 1023iF Black and White...
How could I set up a password for Canon IR 400S? I have access to Advanced Features but do not see whitch button to tap...
try this : press * with head press the custom setting browse it you will find to activate dept code then you need to have dept code id then password for ex.dept code id -0001 password 9999 you need to enter this two info to open the copy functions hope this will help
Jul 11, 2009 | Canon imageRUNNER 4570 Copier
Forgot the administrator dept id et password of my ir2020 canon
go into service mode additional functions button hen press 2 and then 8 keys then press additionl functions button, then scroll through until you see clear press enter and scroll through until you see passwod clear then restart machine and be no administrator password then
May 20, 2009 | Canon iR 2016i Black and White Copier
How to Remove IR400 Dept. ID and Password
Hello, did you try the Clear MMI function ? , it should reset all passwords if my memory is good ( and all settings like ip, language etc ... )
Regards, Mug.
Nov 15, 2008 | Canon imageRUNNER 400S Copier
Canon iR 2016i Black and White Copier Logo
501 people viewed this question
old marine
old marine
