Question about IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R51-monitor too bright
How can I adjust the brightness of IBM YhinkPad R51monitor
  • 447 Answers
Pressing the Fn/Home buttons should increase the brightness, while Fn/End should decrease it. Hope it helps.
Posted on Feb 21, 2009
Adjust screen brightness
go to start-->control panel--->display--->adjust brightness
i need to know what operating system you use this will work for only Vista and 7 and 8 and 8.1
Oct 10, 2014 | IBM ThinkPad T40 2373 Notebook
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
How can I adjust screen brightness?, I acidentally brushed across the keys on the right side and it made the screen darker.
Hi.
Hold down the Fn key which is located at the bottom right of the keyboard and tap the "Home" key which will be on the right hand side of the keyboard, that will increase the brightness. Also to decrease the brightness hold down Fn and tap the "End" key.
Regards.
Jul 16, 2011 | IBM ThinkPad R51 Notebook
IBM Thinkpad R51, screen went dark. At the right screen angle, I can see some light from the windows and cursor, but very faint. At that light angle I can maneuver the mouse and click on windows, so all...
The problem
1 The LCD screen is out or
2 The invertor board behind the LCD screen is out or
3 The backlite is out
You have 2 options
1 To use an external monitor for the time or
2 get the laptop fixed by a tech shop
Nov 18, 2010 | IBM ThinkPad R51 Notebook
Lcd is very dim. after changing res a glow in the lower right corner starts then back to darkness. It works fine with my vga monitor.
Hi, display DIM cause by LCD or inverter Board (brightness controller). Might costly. Up to you either want to change it or not.
And using external monitor is best solution, I think so. =)
May 08, 2010 | IBM ThinkPad R51 Notebook
Dim LCD with a IBM R51
Try updating your video driver. Also, try connecting your machine to external monitor and see if there's a display if not i then confirmed that you planar is faulty.
Note: If machine is under warranty no need to pay for the repairs.
Jun 04, 2009 | IBM ThinkPad R51 Notebook
LCD PROBLEM
It sounds as if you have the screen brightness setting turned way down for when its on the charger. You might be able to adjust this in the control panel under the battery/power options.
Apr 17, 2009 | IBM ThinkPad R51 Notebook
Ibm thinkpad 600x brightness control
There is no otherway. becase the slides sends direct signal to inverter for adjusting brightness. You can adjust brightness the
other way ,through graphic cards property, but that is only adjustment for the color and if you do make it bright, you'll be loosing the vivid color..not so natural.
takecare.
Apr 19, 2008 | IBM ThinkPad 600X Notebook
Laptop brightness
sometimes the power options on a notebook determines the brightness, but if you look to your keypad, there is normally keys that adjust the brightness along with the Fn(function button) But if you have damaged when dropping it, one of the backlights may have been broken within the screen.
May 18, 2007 | IBM ThinkPad R51 Notebook
IBM ThinkPad T40 2373 Notebook Logo
268 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
