Question about Sewing Machines
Need service manuel
Trouble with one thread missing stiches out side needle
  • 26 Answers
Soundss like mine so I cleaned it using canned air and then had to sew on rags for a bit and get the needle to pick it up works well now but I had lots of cursing and purple air about me before I finally got it to work. hope it helps you
Posted on Mar 08, 2009
My stiches are uniform but about every 12 stiches there is a long stich , can you tell me what is causing it?
try to decrease top thread tension a 1/4 notch
check with new needle (may be bent and hook is missing the thread loop)
Nov 10, 2015 | Sewing Machines
With no manuel/thread tension solution?
tighten up the thread tension on the needle thread tension setting
what you describe is a result of the needle thread tension being too loose
to get manuals go google and type in -- workshop manual for ( make and model) sewing machine
there will be pdf version downloads if they are available
Oct 11, 2015 | Kenmore Sewing Machines
My sewing machine straight stitch sews in reverses but misses stiches while going forward
try these suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 24, 2013 | Riccar Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
I have a mega quilter 18 8 and I'm having trouble when I change the needle it will not pickup bobbin or stich
is the needle backwards? flat side usually goes to the back of the machine
is the needle inserted all the way up into the needle holder
Apr 24, 2012 | Sewing Machines
Trouble with the stiching on a juki7800
try changing the needle, make sure the needle is the correct one for the fabric being used
also adjust top thread tension
Apr 16, 2012 | Juki DDL-8700
I have gotten my Mother- in -Laws sewing machine it said on back it is a 1764180 kenmore 24 stich , I can not get it to sew stiches in row it skips , I had no instructions with it for settings etc. can...
Hi Vicki
It's possible that the needle is too small for the size of thread you are using. Also make sure thread is not wrapped around the needle and that the needle is properly seated in the needle bar. It's also possible that the machine needs to be timed and serviced to correct this problem. Is it possible to get the users manual from your MIL? It would have the information you need reguarding needle sizes and threading, etc.
~<Ray>~
Oct 29, 2010 | Kenmore Sewing Machines
Good Morning: My wife has a Husquvarna Viking 320 Electronic Sew Easy. I have tried to re-work the bobin and the thread through the needle. When she stiches the hem on a pair of blue jeans it stiches...
since you are doing jeans it can be on either side so lets start for the beginning, rethread the top thread making sure that the thread went through the upper tension, second remove the bobbin and make sure to thread it through the lower tension(there is a spot on the bobbin case for the thread to go through for there to be tension on the bottom) if the thread on the bottom pulls really easy by hand like there is no resistance then take it to a local dealer and have him adjust it if it feels like there is a pull do the same with the upper thread put the foot down and try to pull the upper thread(don't break a needle) if it has tension adjust the upper thread tension tighter
Oct 19, 2009 | Sewing Machines
Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Oct 27, 2008 | Elna 1010
Sewing Machines Logo
57 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
