Question about Panasonic SC-HT500 System
Not all the speakers are working despite ensuring the cables are
Not all my speakers are working despite ensuring that the cables are connected.
  • Grognard
    Grognard May 11, 2010
    Are you sure that whatever you're listening to is encoded in Dolby 5.1 or better? Most things, including music CDs, will not use all speakers.
  • 8,596 Answers
There is a button that says -Mix 2CH - make sure it does not say Mix 2CH ON, or you will only get 2 channels when watching DVDs. This Panasonic, as well as legions of other home theater systems, are more limited than they seem. The SC-HT500 can give you surround when watching DVD's on the unit, but you will not be able to get full surround for your TV, because the Panasonic does not have the right digital inputs.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
I get no sound from the tv when cable is connect. How do I get sound
ensure your tv is not in Mute mode. ensure your tv does not have Headphones or cable in headphone socket, this will mute the speakers.
ensure the volume is turned up. test your cable on alternate tv if posible to test cable is correct. if still not working, contact Sony customer support.
I hope this was useful
Oct 20, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I need leads to connect my NAD C320 BEE amplifier to PSB T45 speakers. Not sure which plugs are needed to fit into the speakers.
From the C320 manual, Page 5...
11. SPEAKERS
Speaker terminals for speakers with an impedance of 4 ohms or more. Connect the right speaker to the terminals market 'R +' and 'R-' ensuring that the 'R+' is connected to the '+' terminal on your
loudspeaker and the 'R-' is connected to the loudspeaker's '-' terminal. Connect the terminals marked 'L+' and 'L-' to the left speaker in the same way.
Always use heavy duty (16 gauge; 1.5mm, or thicker) stranded wire to connect loudspeakers to your NAD C320. The high-current binding post terminals can be used as a screw terminal for cables
terminating in spade or pin sockets or for cables with bare wire ends.
BARE WIRES AND PIN CONNECTORS
Bare wires and pin sockets should be inserted into the hole in the shaft of the terminal. Unscrew the speaker terminal's plastic bushing until the hole in the screw shaft is revealed. Insert the pin
or bare cable end into the hole and secure the cable by tightening down the terminal's bushing.
Ensure bare wire from the speaker cables does not touch the back panel or another socket. Ensure that there is only 1/2" (1cm) of bare cable or pin and no loose strands of speakers wire.
Register and download the PSB manual for free at retrevo.com
http://www.retrevo.com/support/PSB-T45-Speakers-manual/id/23107ag412/t/2/
If you're pondering those jumpers on the back of the speakers, my advice is to leave them in place and ignore them. Connect the speaker cables to either plus or minus.
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Apr 15, 2011 | PSB Century 600i Speaker
Problem as follow,when using splitter,no receipt
Hi Chris,
Make sure that the splitter is not defective. Ensure the connection of the cable wire. If the symptoms still there despite of good connection replaced the splitter or used cable signal amplifier instead.
Hope it may help you.
Have a nice day.
Feb 07, 2011 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
Despite having disconnected all the speaker cables, protection light keeps flashing
HI...
ALL speakers need to be connected. and if this has settings for 2 sets of speakers , , use the A spkr setting and the A output connects.
If still flashing , try just headphones. If still bad, it will need service.
PLease rate my help if this helps
Sep 25, 2010 | Cambridge Audio Azur 640A Amplifier
No sound
Try a reload, occasionally a conflict of shared files knocks it out.
Jan 07, 2010 | Microsoft Windows XP Home Edition
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Humming noise coming out of the subwoofer
sounds like a bad cable, or a loose connection between the pc and the speakers, or from the main speaker to the subwoofer.
check the connections, or try reinserting the cables to ensure a tight fit. then check the cable from the pc to the speakers. possibly replace 1 cable and see if the problem stops.
Sep 23, 2009 | Logitech X-530 Computer Speakers
Front speaker output is not working
Firstly ensure that the 'mute' has not been accidently engaged.
Have you tried connecting other speakers to the same output and cables? If the sound now works, the problem is with the speakers (providing all amplifier settings are correct and wiring is correct). It would be highly unusual to have a problem with both speakers or two sets of cables. Alternatively connect the problem cables and speakers to an alternative source. If they work on an alternative, you are looking at an amp issue.
Aug 29, 2008 | Yamaha RX-V890 Receiver
Panasonic SC-HT500 System Logo
162 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
