Question about Fujitsu Computers & Internet
How to recover data from corrupted hard drive?
my fujitsu 2.5IN SATA XTENDED DUTY portable hard drive is corrupted and i have very important data stalled inside the drive..can u tell me how to reformat and recover the data?
thanks
    President:
  • 110 Answers
Try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/articles/free-data-recovery-download.html
Posted on Oct 30, 2012
  • 14 Answers
Hi, liub97.
In your case, it is recommended to use this data recovery tool to recover as much data as possible. If you are Mac OS X user, go to this Mac hard drive recovery software.
Then follow the procedure to reformat your corrupted hard drive. Mycomputer -> Computer Management -> Storage-> Disk Management . Note: you can also opt for a third-party formatting tool.
Things are not over, after formatting, retry the program to see if more data can be recovered as you know a simple format option won't erase data permanently.
Best regards.
Posted on Nov 17, 2011
    Scholar:
  • 38 Answers
Plug it into your computer.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data on it with data recovery program to avoid losing your data.I have succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.You can get it here: http://www.any-data-recovery.com After you recover your data,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put it in a zip-lock bag and put it in the freezer for overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And if needed, run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
This article will help. How to recover data from hard drive?
Posted on Jul 27, 2011
    Problem Solver:
  • 8 Answers
Recover programs for hard drive like data recovery there are many out there
Posted on Feb 24, 2009
  • 9 Answers
THIS option should help you out. Connect your corrupted hard drive to your computer first. Then format it from: Mycomputer -> Properties -> Manage -> Computer Management -> Storage-> Disk Management -> select the problem drive and then format it fromhere.
Note: Before formatting, you'd better try a data recovery program to recover data first of all like what has suggested by other members. Here are programs you can take a try. For Windows, go to Data Recovery for Windows; For Mac, go to Data Recovery for Mac OS X.
After formatting, re-use the programs recommended above and rescan the drive to see if you have more harvest. Because formatting won't make files deleted permanently. Best regards
Posted on Aug 03, 2011
    Problem Solver:
  • 18 Answers
Do not reformat the drive right away! Recover the data first of all. There is a chance that you will be able to get back some of your inaccessible data, provided those items were not overwritten (if you continue saving more data to the drive).
First things first: STOP using the external hard dive that you want to recover data from in case you may quite possibly ruin your chances of data recovery.
Then Recommend you have a try of Wondershare Data Recovery, a data recovery program with both Windows and Mac versions provided. It should help you. Get the related versions here,
Data Recovery Windows (for Windows)
Data Recovery Mac (for Apple Mac OS)
Remember - Do NOT try & write anything back to your hard drive until you can recover your data safely!
After you perform data recovery, then use some format tool to reformat the hard drive or format it under "Disk Management" manually. I hope you good luck!
Posted on Feb 02, 2011
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 128 Answers
Card Data Recovery is a nice data recovery program.
Posted on Dec 06, 2011
    New Friend:
  • 4 Answers
Why do you think that drive is corrupted? Is this drive still recognizable on your computer or laptop?
In fact, as I know, as long as this drive is still readable on your computer, you often can take chances with external drive data recovery software to rescue your lost drive files back as many as possible.
So, just plunge this drive to PC and download proper data recovery software to go on, like this: http://freeware-fix.blogspot.com/2013/02/external-hard-disk-format-recovery.html
But, if this drive cannot be read on your computer or other machines any longer, this drive must be damaged seriously. If you really think the inner data is pretty important, some data recovery agencies may help. But, it is not so hopeful.
Note: IN the future, save two or more data duplicates on different storage devices all the time.
Posted on Feb 11, 2015
    New Friend:
  • 20 Answers
Is it still recognized by the computer?
As I know, the corrupted hard drive can be damaged logically and physically.
The logically damaged drive is still fixable and inner data is also recoverable. However, the physically damaged drive is often irreparable and the contained data is also irrecoverable.
So, I hope your hard drive is only logically damaged.
But, now, you can try to use a hard drive data recovery freeware that can deeply scan your drive and do its utmost to restore your wanted data back completely:
http://www.freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Note: You should learn a lesson to back up all your important data at least on two hard drives in the future.
Posted on Sep 13, 2013
    Novelist:
    Scholar:
  • 97 Answers
I recently read an article on hard drive data recovery, from which I learn that deleted files are actually recoverable only if the deleted data are not overwritten, i.e. do not save data to the place where your deleted data once stayed. You might find a better understanding of how to recover data from hard drive if you read this article by yourself. Good luck!
Posted on Dec 12, 2012
  • 18 Answers
All you need to do right now is stopping using the computer where you lost the files. In my opinion, you need some third-party data recovery software to help you. You should download the software from Another Computer. And copy it to a flash drive. This operation is to avoid overwriting your original computer.
Next step is to connect your flash drive to your original computer and run the data recovery software on it. In most cases, if you didn't put new files to the hard drive in which you lost data, you can get back most of your lost files,even they are months ago. If you did, the chance of recovering your lost files will reduce.
Posted on Dec 23, 2011
    New Friend:
  • 46 Answers
It is good to know that we can recover deleted files on our computer these days. We can also recover files using data recovery tool.
Posted on Sep 25, 2011
    Novelist:
  • 241 Answers
Try Kernel for FAT and NTFS, It performs fast and flawless data recovery to easily recover data in a short span of time. Free trial version can be downloaded free from http://www.windowsdatarecovery.com. But, its trial version does not save data. In order to save the data recovered, you need to purchase full version of Kernel for FAT and NTFS software.
Posted on Aug 01, 2011
My harddisk says invalid disk data no data files found
Sorry to hear of your difficulty. Usually in your kind of situation data can easily be recovered using any data recovery software.But my personal suggestion to you is to first try to run a demo version first and if you see directory list of your lost data then only proceed with the purchase.
Sometimes when OS fail to install then file System of your hard drive can go corrupt which can result to invalid disk error.
Regards,
Stellar Phoenix Solutions
http://www.stellarphoenixsol.com
"trusted data recovery solutions"
Feb 13, 2012 | Verbatim SmartDisk Firelite Portable USB...
I have a toshiba 500GB portable external hardrive....it still has 50GB more space left...however when i tried to open it...it wont open and i cant see my files...the computer says that it cannot fix the...
You can recover data from portable hard drive with data recovery software.Tenorshare data recovery is one of the bests. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,bad section, virus attack etc.Download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Jul 10, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
My HP dv200 Laptop video card died now I am trying to recover the data from my HDD [fujitsu MHW2160BH] the problem is that the HDD will not connect in a SATA hard drive enclosure. The connectors do not...
if you look at the connector on the harddrive it is not a sata connector pull tht connector piece off and underneath it is the sata connectors you are looking for.
Jan 05, 2011 | Fujitsu MHW2160BH 160 GB SATA Hard Drive
The file or directory is corrupted and unreadable
You unplugged it when data was still written on it so it was corrupted. Some files are still recoverable so use
http://www.softpedia.com/get/System/Back-Up-and-Recovery/smart-recovery.shtml
to get them.
Jul 03, 2010 | Toshiba 120GB USB 2.0 Portable External...
Hard Drive recovery
Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Corrupted data and folder showing empty.
i just used the scanning process from its property and then got the backup by windows from the properties of hard disk.After doing this all the folders were working.
Jun 10, 2009 | Fujitsu Computers & Internet
Portable Hard Disk not being recognised
If you cannot get the USB connection working, you can recover the data by taking the drive out of the case and connecting it directly to the PC as a second drive.  Make sure the jumper settings are correct for use as a second drive.  You can get the drive information and jumper settings from the web site of the drive manufacturer.
Oct 16, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
1,539 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
