Question about MSI K8MM-V Motherboard
MSIK8Tneo MB Early Chipset initialization comes on on the D-link. I replaced the the Pwr supply as it was bad but still get same issue. Previously I formatted the dive and reloaded XP...My memory is fine as I tested both modules. This is a 754 socket with AMD 3700+ CPU...Machine will boot, post and windows will come up then the machine will reboot and windos won't come up because it's hung at Early chipset inilization. I wanted to reformate the drive but when I boot from the CD I get an error code and the machine crashed. Didn't write down the error code and I am running some diagnostic s/w now. Do you think the board is bad? I also loaded the MB drives after Win XP was loaded. this loaded the ethernet drivers so I could get to the internet i want motherboard drivers beouse i dont have a motherboard cd
  • tazwegion
    tazwegion May 11, 2010
    Bad PSUs can damage a motherboard, I hope this isn't the case with your system...
    * what exactly did you replace the old PSU with?
    * PSU specs?
    * was it new?
    * do the capacitors (cans) on you board look okay OR are the bloated/mis-shappen?
    * does the system power ON easily after it's been sitting in a crashed state?
    Sergeant:
    Novelist:
  • 190 Answers
Your issue may very well be a RAM problem. I use MSI boards for most of my built computers and I have run into this 1 time. Try another stick of ram or if you have more than one in the system use just one at a time and see what happens. Also check to see if you have any Capacitors that are failing. You can tell this by making sure that all the little tops are flat not bulged. If you see any of them bulged you can replace it if you know how to solder but normally this is a temporary fix the board at that time is failing and needs to be replaced. After researching more about this particular board it would appear that the board is picky about its RAM. The driver download page for this board series is located here:
http://www.msi.com/index.php?func=searchresult&keywords=k8t+neo
This is a page with links to specific boards in that series since I didnt know your EXACT model. Click the link to your exact model and then click the Drivers link on your boards page and you will find the drivers you asked for.
Also you may consider flashing the BIOS. Be careful though. If it fails your board will be dead. Follow the instructions for your board to the letter and you shouldnt have any problems.
There is also a driver utility that you can download from MSI that helps you automatically get your drivers and Bios updates.
Hope this helps...
Posted on Sep 21, 2009
    President:
  • 1,447 Answers
May be problem on your coputer RAM you try to install another RAM
Posted on Mar 15, 2010
I m getting c6 code on my msi motherboard 7642
Hello here is the homepage:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
Make sure ALL the drivers is installed on the mainboard:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Driver&os=All
Post Status
FF Power on and first initialize CPU.
C0, C1, C2 Early CPU Initialize.
C4, C6 Initialize chipset.
D4, D5 Initialize memory.
08 Initialize keyboard.
2A, 31 Initialize onboard devices. Load Option ROM (VGA and RAID
option ROM) form BIOS to memory.
37 Displaying sign-on message, CPU information, setup key
message and any OEM specific information.
38 Initialize USB device and different devices.
3C Mid POST initialization of chipset registers. Detect different
devices (parallel ports, serial ports and coprocessor in CPU...etc.)
75, 78 Initialize INT 13 devices and IPL devices. (include SATA/ PATA
HDD and CD/DVD ROM).
87 Enter setup screen. BIOS setup if needed/ requested.
A4 W ait for user input at configuration display if needed.
A7 Display the system configuration screen if enabled.
B1 Save system context for ACPI (Advanced Configuration and Power
Interface). Prepare give control to OS loader (INT 19H).
00 Pass control to OS Loader (typically INT 19H).
AA Enter OS (Vista or W indows XP).
Look also here:
http://www.dewassoc.com/support/bios/awardbios_error_messages.htm
Did you upgrade the ram memory, or the cpu ??
When and how did this problem occur ??
Jan 31, 2013 | Computers & Internet
Computer powers on, but does not boot on an emachines t3624. replaced the power supply
If the fans come on and BIOS does not post (initial screen upon power up), you likely have a mainboard or CPU issue. If a chip fan failed, or your box overheated, your CPU could be fried. Or possibly something on your motherboard got taken out due to lightning, a faulty power supply, etc. If this is the case, you're in bad shape as you're probably dead in the water and need a new MB/CPU.
If you are hearing any beeps upon power up, another hardware device such as memory or a video card (even a defective drive) could be the culprit. If you can try swapping out components to find the one that's causing the failure, and replace that component.
Nov 06, 2009 | Computers & Internet
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Same problem - green "power" LED on the MB but no activity
This series of machines is known for this issue. You can get a replacement motherboard for your pc from a website at www.barebonekit.com they boards run from $35 to about $65 plus shipping. This is much cheaper than you can get them most other places. We order from them on a regular basis and have had no problems. I hope this helps, if so please rate the solution.
Thanks,
Buddy
Jun 17, 2009 | E-Machines T2893 PC Desktop
No power to E-Machine T1860
hi,
Issue seems with the power IC of the motherboard need to repair.
May 29, 2009 | E-Machines T1860 PC Desktop
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
May 15, 2008 | Samsung X05 Notebook
Ultra X3 800 watt power supply
yes PWR SPLY must be connected to MB and MB must be grounded when bench testing. thats the quickest easiest way to check..
Jan 07, 2008 | Thermaltake W0133RU ToughPower 1200W...
I have a rca hdtv r52wh77 1 year old ,i have color problems ,i cant get to the convergence set up ,please help.thks
Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
Dec 22, 2007 | RCA P52937 52" Rear Projection Television
MSI K8MM-V Motherboard Logo
138 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
